Thank you both for the kind input tonight. When you mentioned the FJ springs (as I have seen others on the forum mention them), are these the Moog FJ springs on Rockauto.com that you are referring to?
I did lots of research this morning about the different springs, and from what I can tell, those were the ones that the forum was speaking about.
VT245
Did you have a shop install the Bilstein's on your 4runner or did you do those yourself using the "no spring compressor method"?
I was quoted 300 for installation only of the front Bilstein 5100's on my existing coils. I would be providing the 5100's for them to install.
My other option was for me to obtain a set of front factory coils (either used or new from Toyota) and have them installed on the 5100's and then do the installation myself. My uncle has a lift in his garage that I can use.
What would you recommend for this type of installation?
Thank you for any advise and input!
