Old 01-16-2017, 02:42 AM #1
Porqupine82's Avatar
Porqupine82 Porqupine82 is offline
Porqupine82 will become famous soon enough
GX470 Brake upgrade question
I have purchased GX470/T4R sport Brembo Rotors and pads (I understand the pads are the same as the smaller rotors pads) and I am now looking for a caliper choice that you have had good experiences with. It will need to be the 13WH variety but after reading for hours and hours, I cannot find a caliper that everyone agrees is good. I would prefer calipers that are powder coated or at least painted to protect from corrosion.
Your help would be greatly appreciated!
Please only comment on what you've personally had experience with
Instagram: overland_tennessee
Website: www.redclayrally.com
Porqupine82 is offline   Reply With QuoteReply With Quote
Old 01-17-2017, 06:55 PM #2
Bump
Old 01-17-2017, 07:10 PM #3
084RUNNAH's Avatar
084RUNNAH 084RUNNAH is offline
084RUNNAH is on a distinguished road
084RUNNAH's Avatar
Why not use 5th gen calipers? The sport rotors and pads will work and you won't have to worry about piston seizing
2008 Toyota 4Runner Limited V6
| Spidertrax | OME 886 and Icon Overland Coils | Kenwood DNX9980HD | JL 8W3| HID | Full LED |
| S2000 headlight retrofit | URD Spec U Long Tube Headers | Borla Cat-Back Dual Exhaust | 5th Gen Brakes |
084RUNNAH is offline   Reply With QuoteReply With Quote
Old 01-17-2017, 07:42 PM #4
TrueBlue's Avatar
TrueBlue TrueBlue is offline
TrueBlue is on a distinguished road
TrueBlue's Avatar
Get in touch with Ceika custom brakes and see if there is something that will directly mock up to GX470 rotors. They sell full custom kits that come with powder coated calipers with the options of full floating pistons and stainless steel pistons as well.. they're pricey though
TrueBlue is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 12:19 AM #5
The 5th gen calipers will have the same issue with time... as the piston chambers are still uncoated, which will rust. Come back to this thread in about 6 years and comment on the accuracy of what I just said.
I'm specifically looking for the calipers I mentioned as I've already purchased the rotors.
Old 01-18-2017, 12:36 AM #6
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I would be concerned about the piston chambers being coated with anything as that could introduce variance and looseness over time. But I hear you, we've seen some 5th gens getting seized calipers already, what's worse is when they throw "Les Schwab Specials" or "Autozone Specials" on there and then they seize faster.
I heard the Centric ones are pretty good, those are what I think I will go with when I get the 5th gen calipers for my 4Runner later down the line.
The GX470 calipers are just 4th Gen Sport Edition brakes, so whatever works there.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 12:53 AM #7
shahsmerdis shahsmerdis is offline
shahsmerdis is on a distinguished road
https://www.amazon.com/Advics-W0133-...dp/B00449FCB0/ pretty much heard these are toyota reman company
2004 limited V8
2002 SR5 V6
shahsmerdis is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 12:59 AM #8
Morphyne Morphyne is offline
Morphyne will become famous soon enough
This has me wondering if hitting the pistons with Wd40 or other penetrant/lube would prevent the seize up.
Morphyne is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 01:23 AM #9
chitown40's Avatar
chitown40 chitown40 is offline
Real Name: Rob B.
chitown40 is on a distinguished road
chitown40's Avatar
Real Name: Rob B.
I think that changing the brake fluid (as it is hydroscopic) more often would help reduce the internal corrosion. Changing your brake pads a little earlier may also help reduce the likelihood of a seized caliper as the pistons will not be extended out and exposed to the elements if they have a thicker pad in front of them. As the pads wear, more of the pistons will be exposed and will remain exposed until such time as the pads are replaced. Plenty of opportunity for moisture and other contaminents to get into the pistons.
2009 GX470 Sport Edition w/ KDSS
chitown40 is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 01:47 AM #10
Very good and valid points!
Tundra Brake Upgrade Question Coolman 3rd gen T4Rs 14 07-23-2015 10:42 PM
Tundra brake upgrade question. 3rdgenfan 3rd gen T4Rs 14 07-22-2015 04:04 PM
Tundra brake upgrade question.. Toyotanut 3rd gen T4Rs 3 11-28-2012 03:29 PM
Another tundra brake upgrade question ;) Charlee78 3rd gen T4Rs 5 06-10-2011 08:07 AM
Tundra Brake upgrade question #257 Duhockey 3rd gen T4Rs 6 12-19-2010 06:27 PM
