Originally Posted by NinjaOne
Not sure about those springs, but...
With my OME 884 (590/lbs, 15.35") springs I lost about 1/2" when I added 150lb bumper on my V8. (~2-2.25" of lift after bumper)
I replaced the 884 springs with 885 (590lbs, 15.6") and am now between 2.5" and 3" of lift.
With the higher spring rate, I'd expect a little less droop from the bumper, but not much. I personally wouldn't use the adjustment setting when running a lift springs but find a spring that provides the full lift
Like you said, do it once and do it right.
Thanks for the input, I appreciate it. This is a hold over till I get the loot together for some Icons, so just trying to get rid of some sag I've got going on at the moment. And for $45, I wont be able to complain too much about the new springs once they're in.
If anyone else has any experience, lemme know
