01-29-2017, 10:57 PM
Zero point calibration help please
Today I flushed my power steering fluid by jacking front wheels just off the ground, removing return hose, and turning wheel left to right with truck off (with help, obviously) while keeping fluid topped off. Flush went great. Had wife start truck while front tires were still off ground and turn wheel left to right to bleed any air and check fluid level. All is good. Lowered truck down off jack and cleaned up. Then started truck again and VSC OFF, TRAC, & ABS lights are on . Tried the zero point calibration, which I've done a dozen times before, following the FSM instructions and tips also posted on this forum (using the two wires to short out the two terminals). After short/open 4 or more times in 8 seconds I can get just VSC light to stay on, which is supposed to indicate that I cleared the calibration setting. However, when I shut ignition off, remove wires from terminals, and turn ignition back on, the VSC, TRACK $ ABS lights are on and NONE of them go off after 15 seconds. I cannot get far enough through the calibration phase to get the VSC light off, then reconnect the two lead wires to terminals, turn ignition on, and wait for the lights to blink fast. Can someone please tell me what I may be missing here? Vehicle was parked on level ground with steering wheel straight. I tried the procedure about 10 times today, with no luck. I current
have battery cable off, seeing if that helps delete any code...
Thanks in advance for any tips
01-30-2017, 12:23 AM
Just a thought as you raised front wheels (full droop) and turned fully lock to lock: check the ABS speed sensor wires. If over stretched, one may have failed? That will trip those lights.
1999 BMW M3 coupe(E36) & 2005 V8 sport 4X4 black: ARB bull bar with 4 hella 500s,backup camera in spoiler,VSC off, springs:Tacoma w/ toytec(1/2"Fr) & FJ w/ daystar(1.5"R) spacers,Bora .75" front & Spidertrax 1.25" rear spacers,swaybar bushings upgrade,Stoptech rotors,SS brake lines,RCI Metalworks skids (front, trans.,transfer), Volant CAI,DT shorties w/ Dirty Deeds exhaust,fully soundproofed,Rostra seat heaters,HID (lows),HIR (highs),running board lights (added),aux reverse lights,2006+ tail lights,rear fog mod (tail, brake, directional OR rear fogs),Scion T1819,LED int. lights, key reminder diabled, Land cruiser steering wheel,rear window dog barrier, vent visors, Ultraguage, Enkei Deep Six 20" wheels for summer, factory sport wheels with A/Ts, FJ cruiser wheels with winter tires
01-30-2017, 03:41 PM
Thanks for the tip. I sure did break the right front ABS sensor wire while turning the wheel all the way to the right with the suspension at max droop. I run Icon COs and, at least on my truck, the sensor wire gets pinched against the coil at full turn/droop. It would be hard, but not impossible, to replicate that condition in the field, but I was a bit surprised. I ended up modifying the bracket that holds the ABS sensor wire to the steering knuckle, so that the wire runs [I]inside [I] of the bracket, not outside. That protects it better and allows for another 1/8" or so of clearance between the wire and the coil. All better now.
01-31-2017, 12:12 AM
Real Name: Miah
Real Name: Miah
Nice work brotha, good call. I overlooked that idea/remedy as I was reading the op's issue.
4th Gen 2WD to 4WD CONVERSION
2003 SR5 T4R Pac Blue Metallic w/rear locker, on 35" Mastercraft MXT’s, TC uca"s, TC lca"s, 2.5 King C/O's w/remote resi TC lca gusset kit, Taco Tabs, 2.5 Icon remote resi w/adj on rear Shock Hoops, adj panhqrd A 3.5" lift springs, 10" HD Series AirLift bag, hidden winch W/ 10k Smittybuilt, DMZ eng mounts
01-31-2017, 12:19 AM
Real Name: Ron
Real Name: Ron
That's a good tip. I'm going to (carefully) check my ABS wiring (and brake lines, CV joints, etc.) at full-droop and full lock. I checked full droop at straight ahead, and full lock at normal suspension loading, but neglected to do the combination.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
02-01-2017, 12:35 AM
What surprised me is that the driver's side was not even close to having the ABS sensor wire hit the coil at full droop/turn, while the passenger's side was obviously an issue. I should've mentioned I run Icon 2.5" COs, so the 2.0 or even Bilstein 6100/5112 or OMEs shouldn't pose a problem.
