01-29-2017, 11:52 PM
Complete loss of power when wheeling in 4H
I tried searching and had no luck. I have an 05 limited V8. I've noticed recently when wheeling in Drive and 4H, if I come across an obstacle and there is significant resistance, the vehicle completely shuts off all power. Like I can literally mat it to the floor and it doesn't even rev, but it's still running and everything else is functioning normally. No beeping, no odd lights, nothing... It doesn't happen in any other gear. I've never experienced this in any other 4wd vehicle I've owned.
Any ideas? Is this something I should be concerned about? The truck does excellent offroad and hasn't given me any other problems.
05 Limited
OME Suspension, RCI skids/sliders
265/70/17 KO2's
Instagram: overland_nc
01-30-2017, 01:06 AM
Real Name: Phil
Real Name: Phil
You've found the stall speed of your torque converter and it's at its limit. My suggestion: put it in 4L
Sent from my LG-H830 using Tapatalk
Northwest Trail Innovations Sales Rep. We now have RCV products!
$20 off bumper kits code: instagram
New to me 4th gen runner. To-do list: LED all the things, Roof Rack, Floor Mats, Seat Covers
1993/89 Extended Cab Swapped pickup. Rear ARB, 33s, Rebuilt 22RE, Doug Thorley Header
01-30-2017, 09:42 AM
Real Name: Will
Real Name: Will
Sometimes this is also smart stop nannying you.
T4RNightHawk's Build Thread 2008 V8 4Runner Limited Black
01-30-2017, 11:41 AM
Driving down the short trail to our campsite in Colorado, I never took it out of 4hi or even locked the center diff. Some of the rocks we went over would have dinged the skids on a stock 4th gen. Never experienced any loss of power like you are describing. Anything more gnarly you should just engage 4lo, it'll give you a lot more control.
01-30-2017, 01:10 PM
Real Name: Danny
Real Name: Danny
Pretty sure it's the stability control or something along those lines. In 4hi with the center diff unlocked I've experienced the same thing, especially after a hard hit or dip. Complete loss of power until I shift to neutral and back to drive. Center diff locked with VSC off, same situations and no power loss.
01-30-2017, 02:00 PM
Locking center diff offroad kills the dead pedal nanny (vsc?) I learned this when going from paved to offroad and "seeing how far I could go" with out changing anything, ended up on a bouncy climb with no gas pedal and a panic stop backwards. Locked center diff and pulled away no problem. I've had this happen in snow too pulling out of the neighborhood, spinning tire and accelerator cuts out = no go when you're halfway out in traffic with no power. This is why I put a switch in the master cyl wires line, flip that and get pedal back in cases where it's needed or you want to hoon.
01-30-2017, 03:12 PM
Real Name: Matt
Real Name: Matt
Mine did this to me the other day. I was pulling out of a snow bank where I parked in 4HI unlocked. The wheels spun a little, as expected, but after a second of that it completely cut the power and it was just idling. After I locked the center diff it let me use ATRAC as expected, but it couldn't climb the snow from a stop (or I wasn't patient enough to let it work). I tried again in 4Low locked center with a bit of momentum, and it was fine.
2007 V8 Limited 4WD
01-30-2017, 03:21 PM
Thanks for the input everyone. I don't wheel gnarly stuff in 4h, only while driving FS roads with easy to mild terrain. So being engaged in 4L isn't really necessary for that.
05 Limited
265/70/17 KO2's
01-30-2017, 04:15 PM
Disagree. It's the traction control.
2007 V8 Sport Edition: Definitely Not Stock
2014 LX 570: Stock
01-30-2017, 04:20 PM
Real Name: Phil
Real Name: Phil
Lol this guy's "wheeling" in baby mode?
01-30-2017, 05:01 PM
Yep, its the traction control system. Surprised you haven't activated it that many times before.
2005 4Runner V6 Limited 4WD Pacific Blue Metallic: Bilstein 5100 + Moog FJ Springs front, Superflex rear, OEM LED tails, Dinoc woodgrain conversion, Kenwood DDX371
01-30-2017, 05:33 PM
Maybe I should have went into further detail in my OP, not heavy wheeling. I mean cruising fire/forest service roads with light to mild terrain. So 4L isn't needed.
05 Limited
265/70/17 KO2's
01-30-2017, 05:34 PM
Real Name: Phil
Real Name: Phil
Gotcha lol..
01-30-2017, 09:59 PM
best thing to do is to keep your foot where it is on the throttle. the ATRAC will begin applying power to wheels and assist you. Give it a shot or google videos on 4runner atrac to see it in action.
2006 SR5 V6, Bilstien 5100s, FJ Coils- Front and Rear, 1.5 rear Daystar spacer, 265/75/16 Geolander AT, ETrailer hitch
