Old 02-17-2020, 04:32 AM #31
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Originally Posted by mcplwray View Post
Hi Earthrealm. I saw this post but could not find the post you referred to. I have an 05 4.7 4Runner that I need to do a zero point calibration with and it seems the 05 was in the middle of things changing. Any help would be greatly appreciated.
for an 05, use pin #12, and not pin #14.
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 09:03 PM #32
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
I just had to do this on my 04 after hooking up a scanner to reset a TPMS fault. I get so much information from this website so I wasn’t surprised when I typed in “zero point calibration” and was redirected back to my favorite T4R website!! Thanks so much to everyone who gives out their knowledge. I appreciate it and so do so many others.
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 03:54 PM #33
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
What was the original code that you cleared?
Why do you think a zero point calibration will fix the underlying problem that activated the code?
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 04:56 PM #34
Bassturd's Avatar
Bassturd's Avatar
I can’t remember the actual code but the scanner I use had a description of the fault stating the yaw tilt sensor needed a zero point calibration. Then I researched that. Google stated that 04 and older 4runners and possibly other models had a possibility of that coming up when an ODB 2 scanner was hooked up. I then typed in zero point calibration and it directed me to this thread. I knew it had to be something I did with my scanner since I only had a TPMS fault and I have never had VSC lights on in the past. The lights weren’t on when you start the vehicle but the second you put it into park or drive and moved the vehicle an inch both VSC lights would come on.
2004 SR5 V8 AWD
Old 07-02-2021, 12:02 PM #35
Capt Kirk Capt Kirk is offline
Capt Kirk is on a distinguished road
Just a quick question concerning the zero point calibration, people keep referencing pins 4 & 14, but my chart shows pins 4 & 12???? Am I looking at somethinmg different here, or does the pin location change with vehicle model year??? I have a 2006 that I need to calibrate but don't like the idea of making smoke by plugging in the wrong pin location
Capt Kirk is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 01:16 PM #36
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Toyota changed the OBDII protocols in 2005. Pre 2005, the correct pins were 4 and 14. Post 2005 the correct pins are 4 and 12. If you have a 2005 it could be either, depending on mfg date.
Scroll up in this thread and you'll see further discussion on this.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
trac light , vsc , zero point calibration
4th gen (06) zero point calibration rikclark 4th Gen T4Rs 3 08-14-2018 12:14 AM
Zero point calibration help please pearlj10 4th Gen T4Rs 5 02-01-2017 12:35 AM
zero point calibration riceandpho 4th Gen T4Rs 2 06-14-2014 06:45 AM
Zero Point Calibration on 04 V8 dave4242 4th Gen T4Rs 3 04-20-2013 07:29 PM
Zero point calibration Help? 4runner_03V8SPT 4th Gen T4Rs 0 10-17-2010 05:50 PM
