Real Name: Ron
Real Name: Ron
Toyota changed the OBDII protocols in 2005. Pre 2005, the correct pins were 4 and 14. Post 2005 the correct pins are 4 and 12. If you have a 2005 it could be either, depending on mfg date.
Scroll up in this thread and you'll see further discussion on this.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
