Originally Posted by lbhsbz
Get the specific codes and I can point you to some testing to pinpoint it.
Cam solenoid codes will be electrical faults...cam position codes and cam/crank correlation codes are because the cam timing is not as commanded by the ECM. Could be anything from a jumped chain, sludge clogging up the VVTi passages/solenoids/actuators/screens. Oil would have to be pretty low...you'd hear a bunch of racket from the chain tensioners not pressurizing most likely.
I have a similar problem2008 Gen.4 4runner V6 275K miles recently the check eng and vsc lights came on.
CODES: P0335, P0340, P0016, P0012, P0011.
It starts and runs but not as strong as usual. Any thoughts?
