02-11-2017, 10:18 PM
Real Name: Nate
Real Name: Nate
Headlights not working on low, high beams working. HELP
Just hopped in my truck to go to dinner and the low beams wouldn't work. High beams worked, didn't test the fogs. Low beams definitely worked yesterday morning, not sure what might have caused them to suddenly not work. Anyone have any ideas? Has this happened to anyone else? Ill have to loook into it tomorrow, but I have no clue where to start. Thanks everyone
Sent from my SM-N920V using Tapatalk
02-12-2017, 12:26 AM
Hmm ... if it was only one headlight not working on low beam, I'd be thinking either the bulb or the fuse. But with both not working, I might first check on the headlight relay circuit.
http://4runnerclub.com/i/4r_files/fs...err/049005.pdf
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
02-12-2017, 09:29 PM
You can swap lights left to right. See if its just the bulb. I just went thru this. It was my light socket. Had to get a new headlight socket at autozone and solder it on. Now percect. Hopefully this helps.
02-12-2017, 09:47 PM
Real Name: Skip
Real Name: Skip
If neither of his low beams are working this isn't going to work, either both sides are burned out are neither side is getting voltage, he could however remove bulbs from the foglights and try them since both the low beams and foglights use the same bulbs.
2004 Limited V8
02-12-2017, 09:57 PM
not unless its a 2006-09 model years, h11 for lows. 9006 for fogs and 9005 for highs.
03-05 is 9006 lows and fogs and 9005 for highs.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
02-12-2017, 10:08 PM
Real Name: Skip
Real Name: Skip
Yeap, I forgot they changed the lows in 2006, I guess it would help if the OP stated what year T4R he has???
Edit: Just notice the OP user's name "buckeye4runner08", so I guees it's safe to guess he has a 2008.
2004 Limited V8
02-12-2017, 10:17 PM
Once in 35 years of driving I had both low beams burnout at the same time. Immediately though it was a electrical gremlin started tearing into the nissan, found nothing wrong, pulled a bulb, tested open, same with the other.
New bulbs and presto, light
YMMV
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
02-12-2017, 11:19 PM
Yah i missed where he said both quit. Gotta trouble shoot it down. Might be just time for bulbs.
02-12-2017, 11:29 PM
Real Name: Brad
Real Name: Brad
Same thing happened to me before. Turned on the truck to go to work, no low beams, so drove the wife's car. When I got back home, I started digging through wiring diagrams, just wondering what hell I was in for - then I swapped my driving lamp bulbs ('03) to my low beam positions & voila! FIXED!
Don't go for the hardest fix. it may actually be the easiest one!
Now I tend to keep spare bulbs on hand.
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
