The only 33s you will install without rubbing are the 255 skinny tires. you are going to rub with 285s more than likely regardless of the rim.Your rub points are the tire well liner and or the outside of the front bumper due to pushing the tire out with offset aftermarkets or spacers on your stocks. Without the spacers, you risk rubbing the UCA with 285s. I have never heard of anyone having rub issues with 255s.
Also a lot depends on the tire BFGs will rub more than say a dueler AT because of the tread blocks and sidewall.. Hope this helps
2006 SR5 V6, Bilstien 5100s, FJ Coils- Front and Rear, 1.5 rear Daystar spacer, 265/75/16 Geolander AT, ETrailer hitch
