Old 07-30-2020, 09:44 AM #16
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Looks to me like you would need video documentary to remember how it all goes back together. smh
If you did all that and DIDN'T change the expansion valve? You would regret that one for awhile if it ever went bad.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 09:54 AM #17
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
That's solid logic, not arguing that at all. I'm not DIY'ing this job as I do most other things. I have a trusted indie mechanic I go to for anything I don't want to mess with, and this is one of those things.
I just ask because his advice was not to replace it unless it needed it because he hadn't seen a bad expansion valve on a 4th gen, but now I'm second guessing his advice.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 10:12 AM #18
Real Name: Brett
Real Name: Brett
I guess I read that wrong. I thought he was saying to change it out. If you do change it I would source an OEM replacement to avoid being bit by a cheap bootleg part. There has been a few stories about certain parts getting copied over the past few years. It's just too difficult of a spot to get to without making sure.
Old 07-30-2020, 10:20 AM #19
Zero0575's Avatar
Real Name: Casey
Zero0575's Avatar
Real Name: Casey
I may not have been clear, sorry. By "He", I meant my indie mechanic - the indie mechanic said not to replace the expansion valve because he had never seen one go bad on a 4th gen. The person I quoted on the forum here advocated to replace it, so I was just wondering if he had experience of it actually failing.
I've already had the work done (evap core), but now my OCD is wondering if I'm going to potentially have to pay to have the dash torn apart again in the future because I didn't have the expansion valve replaced. I'm already kicking myself for not having the expansion valve replaced, but I always listen to this particular mechanic's advice because he's never steered me wrong. Hoping that no one actually has experience of it failing so my mind can be somewhat at ease.
Old 07-30-2020, 12:03 PM #20
Real Name: Brett
Real Name: Brett
Yea if your mech. says it's not high fail item, don't lose any sleep. It is what it is at this point. My experience is not anything compared to a pro, and it was just an observation. You should be fine.
Old 09-16-2021, 01:21 AM #21
flatlanderaz flatlanderaz is offline
flatlanderaz is on a distinguished road
It’s my turn😢.
2005 limited 4x4 T4R, 190k miles started blowing warm on driver side a couple weeks ago. Did usual, freon low so added dye. Can see where it is coming from drain tube under passenger side. I’ve added some freon just to see if it gets cold again and it does but without proper tools, not willing to put in a bunch. Those OTC gauges that come with the freon/dye products might not be most accurate and don’t want to overfill.
Here’s my question: I took apart our 2010 Rav4 to the firewall 6 months ago dealing with the diverter flaps. Got lucky and was able to fix that issue and put it back together, with no extra pieces!
I don’t have a vacuum pump, gauges or a repair manual. I am 100% certain I can get to the evap. but without the manual and various AC specific tools, any advice on if this can be done buying or renting some of the tools, maybe from an AutoZone. I imagine Harbor Freight also carries some of the items. Just lacking confidence on the AC portion of the job.
Yes, money is playing an issue. I have not started looking around town but from what I know on labor taking this apart, got to be looking at $2000+. If I replaced just the necessary part(s), what am I looking at in costs? Half that or $1000?
I know you all don’t know me from Adam but any input is welcome. Plus, I’m in Southern AZ so if you know anyone you can recommend that might be a better choice than me, maybe I just have it done. It was a good 8 hours to get the Rav4 apart and back together and yes, my back was sore after.
Thanks in advance for any input.
J
flatlanderaz is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 11:45 AM #22
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Originally Posted by flatlanderaz View Post
It’s my turn��.
J
I did this a few months ago and had no experience with A/C systems in general. It took a significant effort but none of it was hard and I rented the manifold, etc, from Autozone for free.
I took it to Toyota for a final evac/recharge (more so to check my work) and they found no issues. For the whole job here in KC, the dealer was $2200 and my local Toyota shops were all $1500. The critical parts themselves are less than $100 but if you're going to that extent, there are a few other things you may want to consider replacing (I did condenser too, as the dryer needs to be replaced if the system has been opened).
I'm working on a detailed write up but due to the sheer number of steps, it's taking awhile. That said, I saw another member posted a step-by-step YouTube video recently that would be all that you'd need.
If you get into it and have questions, PM me and I'll give you my cell #.
eleven14 is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 01:19 PM #23
thomas.william7895 thomas.william7895 is offline
thomas.william7895 is on a distinguished road
My AC has gone out as well... I hope it's an easier fix than this...
thomas.william7895 is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 11:02 PM #24
BostonJon BostonJon is offline
BostonJon will become famous soon enough
I’ve done this repair on various Jeeps over the years as well as my previous 3rd gen. It’s tedious but very manageable if you’re organized and document your work with notes and pictures.
With the exception of gauges and a vacuum pump, it’s all basic hand tools.
BostonJon is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 10:55 AM #25
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Give this product a try. Could save you a lot of work. Has good reviews. It should fill small pinhole leaks. They have a small size for automobiles as well.
A/C EasySeal Nu-Calgon
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 10:49 PM #26
Thx for the reply. I need to figure out how to PM on this board. I will take you up on it if/when I get to it. Quick question, where did you source your parts. I’ve read some issues with getting bad (new) knock-off parts. If I have to buy from dealer I will but if there is a rep source that is less expensive, I’m in for that.
Old 09-23-2021, 11:17 PM #27
Sounds good. I used a combination of Rockauto.com for Denso parts and my local Toyota dealership.
Avoid ebay/Amazon, the reports you've read are accurate and with the amount of labor involved, I simply wasn't willing to risk getting a knock-off to save a few more bucks.
Old 10-27-2021, 03:06 PM #28
audio audio is offline
audio is on a distinguished road
Question Cut a hole
My 4runner developed the dreaded evap leak.
I was given 2 options -
1: $1600 to repair (taking out entire dash)
2: $1000 to disassemble part of the dash and cut hole and take out evap/parts that need changing.
I asked if there's any negative to cutting the hole and they said no and they did it many times before for the police dept. etc...
I went with the hole and they did the job in a few hours.
When I went there I asked where the hole is cut and they said inside the dash.
I have never heard of this before, but I guess it works. Just another crazy option.
audio is offline   Reply With QuoteReply With Quote
Old 12-13-2021, 04:27 PM #29
Gasass Gasass is offline
Gasass is on a distinguished road
Any more info on this repair? I have to do this to my '06 very soon... Florida sun is HOT!!
Gasass is offline   Reply With QuoteReply With Quote
Old 12-17-2021, 11:57 AM #30
Update
Weather cooled off a bit here in AZ so going to put off until spring. In the meantime, for the life of me, cannot figure out how to PM a member on this board. I even contacted the forum help desk and they never answered the question. I intend on doing this job in a few months. In the meantime, I think I’ll replace my leaky rear suspension (x-reas) with an all new suspension. That could be fun👍🏼
Dreaded Transfer Case Leak LeesO4 4th Gen T4Rs 12 02-10-2016 11:24 PM
The dreaded front axle seal leak Jester4kicks 4th Gen T4Rs 5 03-13-2015 09:34 PM
Opinion on dreaded transfer case leak - 2005 V8 pgellers 4th Gen T4Rs 13 09-22-2014 03:43 PM
EVAP Line Leak & VSC LIGHTS ehampt 4th Gen T4Rs 0 09-21-2012 01:52 PM
Problem with the Evap leak help? alexb18c1 4th Gen T4Rs 0 01-02-2009 01:58 PM
