Old 03-14-2017, 09:24 AM #1
Morphyne Morphyne is offline
Morphyne will become famous soon enough
When to change shocks???
So I understand the basics about changing shocks. Bottoming out, swimmy steering, diving when stopping. I am not having any of that. but what I do have is a lot of roughness from side to side (lateral movement). Setup is bilstein 5100s, levels, with MOOG FJ cruiser springs all the way around. springs and shocks have 60k on them.
Morphyne is offline   Reply With QuoteReply With Quote
Old 03-14-2017, 09:49 AM #2
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
A nice and simple test is push each corner of the vehicle down as hard as you can and watch how the suspension behaves controlling the rebound. Good shocks should control the bounce by allowing it to rebound once and then compress just a little to return to normal. More than one rebound means they are probably done for.
techno is offline   Reply With QuoteReply With Quote
Old 03-14-2017, 09:54 AM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Bad shocks wouldn't necessarily cause "roughness" like you describe but if they are getting old, your suspension will continue to oscillate after hitting a bump because your springs aren't being dampened efficiently.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 03-14-2017, 11:32 AM #4
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
elaborate on 5100 strut settings?
If your preloading the MOOG coil on the 5100s upper settings its going to result in a rough ride b/c youve reduced the travel of the coil
jrm is offline   Reply With QuoteReply With Quote
Old 03-14-2017, 12:02 PM #5
Inv4drZm's Avatar
Inv4drZm's Avatar
*Reduced the down travel
The total travel remains the same.
when to change shocks moloss 4th Gen T4Rs 44 09-28-2015 07:02 AM
Will or should low mileage oil change standards change related to warranties 5,000/6m jow 4th Gen T4Rs 2 01-08-2012 08:03 PM
Do I need to change both shocks and struts for a softer ride t4fan 4th Gen T4Rs 7 06-29-2011 11:23 AM
Xreas front shocks change cost d_cool 4th Gen T4Rs 10 11-07-2009 12:27 PM
