Originally Posted by jminz
Rather than connecting pins to check trans temp can I just monitor on my torque app and check it when it's reached correct temp?
That is what I did when changing my Tranny fluid. I had searched around and found 2 or 3 methods for setting up a trans temp gauge in torque and I just watched those until it reached the needed temp.
Word or caution, be sure to double check the procedure on when to pull the overflow plug (I think that's what it's called) on the tranny.
If I remember correctly, you're to remove it once the temp is reached and while the engine is still on.
I kept shutting the engine off before checking when I was working on mine, so I'm not sure I got the amount correct (any how, it's been over a year and everything (seems to be) working fine).
