Camburg UCA bushing washers
Hey group...
I'm getting ready to install Camburg UCAs (and other goodies) that I picked up from another forum user. The kit was missing one of the bushing washers, so I am trying to track down another. Toyota wants $15 for a set of two, but the OEM design appears to only use two washers per side like the new lightracing setup.
Does anyone have experience with the Camburg setup? Is it necessary to use 4 large washers per side or should I replace the inside washers with smaller diameter like the light racing setup? The PDF from the camburg site shows that the bushings are a split design, which would explain why a large washer would be needed to keep both halves of the bushing pressed together, but I don't pretend to be an expert on these things.
Thoughts?
2005 Limited V8- Stratosphere Mica
LED Interior, Constant Fog, OEM Nav, Encore E9 Alarm/Remote Start, Rear Air/XREAS converted to FJC, Vantrue R2 Dash Cam, Camburg BJ UCAs, Bilstein 6112s, CBI ditch brackets with Auxbeam 4" flood LEDs
