06-21-2019, 05:19 PM
#496
Going from XREAS (100,000 miles) w/ Daystar 2.5"/1.5" spacer lift and 265/70R17 tires to Dobinsons C59-677V rear coils with 285/70R17 tires I gained 2.9-3" hub to Fender and 3.5-4.5" ground to fender.
Finally got my suspension all installed and tested out. It has been on for about a month and a half now so assuming it has settled if it has at all.
What I am running:
Front:
Elka 2.5 Reservoir with DSC
Eibach 14"x650# spring installed (replacing 13"x700#
Total Chaos UCA with Delta joint
Timbren Active Offroad Bumpstops
Rear:
Dobinsons C59-677V
Before I lifted I was running XREAS with Daystar 2.5"/1.5" Spacer lift on 265/70R17 wheels.
Measurements before:
Driver Front-
Ground-Fender: 36"
Hub to Fender: 21 1/8"
Passenger Front-
Ground-Fender: 36"
Hub to Fender: 21"
Driver Rear-
Ground-Fender: 36"
Hub to Fender: 21 1/2"
Passenger Rear-
Ground-Fender: 37"
Hub to Fender: 21 3/4"
After the lift I upped my tire size to 285/70R17's.
Measurements are:
Driver Front-
Ground-Fender: 38 1/4"
Hub to Fender: 22 1/2"
Passenger Front-
Ground-Fender: 38"
Driver Rear-
Ground-Fender: 40 1/2"
Hub to Fender: 24 1/2"
Passenger Rear-
Hub to Fender: 24 1/8"
Whytey's 07 V8 Build Thread
2007 Toyota 4Runner Sport Edition V8, Elka 2.5 Suspension, Total Chaos UCA w/ Delta Uniball, Dobinsins C59-677V Rear Coils, Timbren Bumpstops, Prinsu Design Roof Rack, Baja Designs Squadron Sport Fogs, 285/70R17 BFG KO2, Blacked Out TE Rims, Spidertrax 1.25" Wheel Spacers, Satoshi Grill
06-22-2019, 12:48 PM
#497
suspension installed !
need your thoughts, will rear settle a little ? should I consider C59-505 or does it look fine the way it is ? Current set up is C59-302 up front and C59-325 in rear
2005 limited Dobinson suspension/ 86 Turbo SR5 4Runner, TEC T3 turbo,2.5 " exhaust, ARB suspension, Rustoleum paint (Money pit)
06-24-2019, 10:59 AM
#498
Was this right after installation? It does look a bit taller, not yet settled.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
06-24-2019, 04:44 PM
#499
this was 4hrs after install. I will give it some time to settle
06-24-2019, 05:31 PM
#500
Yeah, it takes about 500 miles for the coils to break in and settle. Make sure the pigtail of the coils are against the step in the coil seat on the axle properly too.
06-26-2019, 07:11 PM
#501
Are you guys planning on having a sale for Independence Day?
Considering the below set up for my V8
Front:
C59-314
GS59-221
Rear:
C59-325
GS59-637
06-27-2019, 09:53 AM
#502
Front:
C59-314
GS59-221
Rear:
C59-325
GS59-637
No, no sales coming, sorry. We're actually having to do a price rise very very soon, since people keep playing with the import tariffs into the USA....
06-27-2019, 05:34 PM
#503
As a newbie there are so many suspension options available to me.
I still have yet to hit my 15 post count to be order to post my own thread and build thread but I wanted to shoot my shot here.
I am looking to get about 3 inch total rise out of a suspension lift. What components from your catalog of products would I need to accomplish this with a 110lb Coastal Offroad metal front bumper and an otherwise completely stock 2004 V8 SR5 with no XREAS.
It will be mainly used as a commuter but the entire reason why I bought this 4runner was the ability to wheel.....in style.
I look forward to hearing back from you and possibly snagging a set before the price rise due to the terrible tantrums from a certain someone to increase the tariffs.
06-28-2019, 09:27 AM
#504
Hey man, so for 3" front and rear with that bumper, here's what I'd suggest
C59-314
GS59-220
UCA59-002K
DD59-529K
C59-677V
GS59-701
06-30-2019, 02:21 AM
#505
I have a 2005 GX 470 with KDSS and want to do 3" front and rear to get a factory rake. I'll have no additional weight other than the occasional camping/fishing/hunting. I would like it as comfortable as possible due to having 2 kids. What's your recommendation? I know I'll need to do a coil conversion in the rear and was also told that KDSS equipped vehicles may need different springs for the left side?
Oh, I'm already planning to get SPC UCA's as well.
@dobinsons_mike
07-20-2019, 07:04 PM
#506
could I just add 1/4 in spacer up front to help level ???
07-20-2019, 08:58 PM
#507
Real Name: Ron
Real Name: Ron
swerks
what wheels do have? I like them!
07-20-2019, 09:11 PM
#508
tundra wheels
07-21-2019, 02:23 PM
#509
Sure, it will add 1/2" of lift
07-21-2019, 05:44 PM
#510
Just installed a Dobinsons lift kit on my 2005 SR5 V6 4WD and am thoroughly impressed! I have had 5 Toyota trucks, most of them lifted, and this suspension has the best feel. Slightly firmer than stock but it still soaks up bumps on the road very comfortably. I achieved the exact stance and amount of lift that I was hoping for.
Front: C59-300/GS59-221 (with 5mm driver spacer installed)
Rear: C59-505/GS59-705
Wheels: Fifteen52 Turbomac HD 17x8.5, Bronze
Tires: Kuhmo Road Venture AT51 265/65/17
Cheers to Mike for great customer service and a great product.
