04-02-2020, 09:16 PM
#706
Originally Posted by Drift Monkey
Ok cool, was checking because the bushing doesn't look nearly as squished as other pics I've seen.
UCAs are nice and greased, wiped em all up each week as they started to seep. I could try tightening again - I think it was in the air iirc. I'm assuming you mean the UCA bushings? I also recently did my LCAs too shortly after the lift (frozen arms/bolts).
Now to find those UCA torque specs...
If Dobinsons assembled the struts, then they are correct. They look right to me.
The UCA bushings where the big long bolt goes thru. They need to be torqued on the ground.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
04-02-2020, 09:29 PM
#707
Hmmm....the instructions on my UCAs had me torque them while off the ground and grease afterwards.
I can still try the UCA bolt (if I can get the torque wrench in there) - I'm pretty sure my new LCA cam bolts were loosened/re-tightened during the alignment (full weight on the rack) so that probably isn't it. Think it could be the sway bar?
Thanks heaps
@ Crikeymike
2006 4Runner Sport Edition V8 4WD
04-03-2020, 09:14 PM
#708
Should I be worried?
04-03-2020, 09:38 PM
#709
Doesn't look like the top washer below the mount is centered in the mount properly. Plus the bushings aren't preloaded all the way.
Start at 17:30 in this video
https://www.youtube.com/watch?v=CmjVHhuT1vU&feature=youtu.be
Sent from my SM-G973U using Tapatalk
04-14-2020, 03:10 PM
#710
Is there a Dobinsons torque spec to the top nuts? They look all the way down and I've checked everything else - even took the sway bar off which helped a bit with the harsh rebound feel over speed bumps/steps. Maybe that's just the higher spring rate and I'm not used to it - that honestly might be it lol.
04-15-2020, 08:56 AM
#711
That's an awesome video. Thanks for taking the time to put it together.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
04-15-2020, 04:55 PM
#712
OME rear trim spacer
will OME rear trim spacer work with Dobinson ?
2005 limited Dobinson suspension/ 86 Turbo SR5 4Runner, TEC T3 turbo,2.5 " exhaust, ARB suspension, Rustoleum paint (Money pit)
04-15-2020, 05:01 PM
#713
Yeah, shouldn't be a problem.
Dobinsons also has a 15mm rear spacer: Dobinsons Rear Spacer, 15mm | 4Runner FJ Cruiser Lexus GX470 GX460
04-15-2020, 06:27 PM
#714
I'm looking for some more lift and flex. Right now, I have 5100s all the way around, front set to 2.5". I have a 2" spacer on the rear stock springs. I would love to have an extra inch in the front and an extra inch in the back and the Dobinsons have caught my eye. I do not carry any load as of now however sliders and skids are in the near future. Any recommendations?
11 smiles per gallon
04-15-2020, 07:12 PM
#715
Sure I can make a suggestion.
What engine do you have?
And are you talking about 1" taller than it is right now? It might be sagged since you're still using stock springs. Or a 3.5" front lift and a 3" rear lift with stock weight?
04-15-2020, 09:05 PM
#716
Dobinsons Suspension - 4th Gen Options
V8. And I was hoping for 3.5 in the front and 3 in the rear.
04-15-2020, 10:18 PM
#717
OK. C59-314 on the front set to whichever clip height is 1/2" up from the bottom would get you 3.5" up front.
C59-677V in the rear would be 3"
04-23-2020, 12:33 PM
#718
Me again. So, turns out that I will be getting the Coastal Offroad bumper as well as a winch. What front and rear combination of coils should I get for 3" in the front and 2.5" in the back? I have 5100s and a V8.
04-23-2020, 01:23 PM
#719
C59-354 set to the first clip up front, and C59-675V in the rear would get you going.
04-23-2020, 06:27 PM
#720
What is the expected average life of the MRA’s before a rebuild is required? (I know this is rather subjective, just a ballpark...)
Is this something that we can do ourselves? How much is the kit?
If we need to send them in... where to and what is the turn around?
And what is the coupon code for 20% off if I buy the whole kit and kaboodle from you guys? 😏
Thanks for all of your help, and my apologies if you answered these already. I looked but didn’t have any luck.
