Crikeymike
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 06-14-2021, 01:57 AM #1036
chris27 chris27 is offline
chris27 is on a distinguished road
Originally Posted by Crikeymike View Post
That's right but it's too much lift. You would have no down travel and it would ride really firm. Better off using the 302 coils and setting the height to no more than 3.5"
Got it, thanks! Sorry, one follow up question. I have fairly new Bilstein 5100's, if I went with 675v's in the back will they work for a while before I can upgrade to your shocks? I'd like to save up for the IMS ones if I can. Seems like the extended length is enough based on the specs, but wanted to make sure.
Sent from my SM-G965U using Tapatalk
chris27 is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 09:20 AM #1037
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Yes that should be OK
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 03:28 AM #1038
joshik joshik is offline
joshik will become famous soon enough
finishing spec'ing out the kit
i'm set on getting the rear long travel setup with the 675v (no rear bumper or anything) + 575 long travel rear shocks. I know ext bump stops + brake lines are a must. I saw you have the Wheeler rear bump stops. Would you need just the Wheeler rear bump stops or would one need the extensions as well?
Also, would the rear 4.25" durobumps work as well for the rear long travel setup? I really dont want to bottom out and blow out the shock :P
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 10:17 AM #1039
Crikeymike's Avatar
Crikeymike's Avatar
The durobumps would actually work better to protect the shocks from bottoming out, so if you haven't bought any yet, those 4.25" would be ideal.
Or the Timbren's also cover it for the LT shocks and don't let the shocks bottom out.
Old 06-15-2021, 11:20 AM #1040
Runn4theHills Runn4theHills is offline
Runn4theHills is on a distinguished road
Hello, I'm looking to purchase a kit from someone who bought the kit directly from Exit Offroad and I'm hoping that you can help me confirm that these are the right part #s for my 2006 4Runner v8.
Here is what he has:
C59-302R
GS59-701B
GS59-220B
C59-327R
Any info that you can provide would be greatly appreciated! Also, would it be necessary for me to upgrade the upper control arms with this setup?
Runn4theHills is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 05:10 PM #1041
Crikeymike's Avatar
Crikeymike's Avatar
C59-302R
GS59-701B
GS59-220B
C59-327R
Post #1 of this thread will show you what those part numbers will give you, but to summarize, Yes, all of that will work. It will be 3" up front (yes, UCA's are needed) and those are the heavier rate rear coils, 2" of lift with 200-400lbs of weight, otherwise they'll give 2.5" of rear lift with stock weight.
Old 06-15-2021, 11:26 PM #1042
sweet! Timbrens look awesome but way more exp. The duros dont compress so much that they will still bottom out the rear shocks?
Old 06-16-2021, 10:05 AM #1043
Crikeymike's Avatar
Crikeymike's Avatar
Don't know, I don't sell Duro's so I don't know what their compressed length is. you'll have to ask them.
Old 06-29-2021, 12:29 PM #1044
I talked with Durobump and they said that that 4.25" stops won't work with the Dob LT rear setup. They recommended the 5.25" stops which is new and not fully available yet. They sold me a pair directly so I will report back once I get everything installed.
Also, does anyone know if you can adjust the front coilseat while the coilover is on the car (on jacks with front end at full droop)? I know Dob doesn't recommend it but I was hoping it is possible to do some fine adjustments to front end height.
My brother has the Fox 2.5 DSC fronts and he used a punch to turn the collar. He says lots of peeps do that.
Old 06-30-2021, 01:01 PM #1045
Crikeymike's Avatar
Crikeymike's Avatar
Free shipping on any order of $500 or more from now until midnight on 7/7/21 EDT. Excludes all armor, leaf springs and awnings, and drawers, but applies to all shocks, struts, coils, UCA's, etc
https://exitoffroad.com/
First, add items to cart, go to checkout, use coupon code “JULY4TH” for the discount to be applied. Not valid with any other discounts, will not work with excluded products in the cart (remove those and buy separately)
Dobinsons Suspension - 4th Gen Options-4thjulysale-jpg
Old 07-09-2021, 11:24 AM #1046
TN4Runnin's Avatar
TN4Runnin TN4Runnin is offline
TN4Runnin is on a distinguished road
TN4Runnin's Avatar
Hello,
I have a 4th Gen V8 4WD SR5 I just picked up. I am planning on installing a Shrockworks bumper w/o winch for now (net +~115 lbs), and a True North rear bumper with swing out for spare tire (not sure weight, say ~200lbs)
Currently stock suspension, 17” stock wheels and 265/65R17 Yokohama’s. Will get Black Rhino 17s and new larger A/T tires as well.
Based on the above, is there a configuration you would recommend specifically for a 2-3” lift? Thank you
TN4Runnin is offline   Reply With QuoteReply With Quote
Old 07-09-2021, 12:10 PM #1047
Crikeymike's Avatar
Crikeymike's Avatar
Originally Posted by TN4Runnin View Post
Hello,
Hey. Welcome to the 4Runner world!!
Yeah, I can make suggestions. It really depends though if you want 2" or 3", as it's different parts to get you there. And then some want to try and level out the truck some, so 3" up front and 2" in the rear is a super common way to go. 3" front requires UCA's as well to get the proper alignment and articulation out of the front end.
Old 07-09-2021, 12:24 PM #1048
TN4Runnin's Avatar
TN4Runnin's Avatar
Thanks for the quick reply - definitely want to level it out as much as possible.
So 3” up front + UCAs, 2” rear, and then I believe I can choose different coils based on the added weight I estimated?
Old 07-09-2021, 02:45 PM #1049
TN4Runnin's Avatar
TN4Runnin's Avatar
Thumbs down
AKA, the attached perhaps?
Dobinsons Suspension - 4th Gen Options-7e563dc7-0e1c-4ee3-b7de-68c3b2650ba2-jpg
Old 07-09-2021, 03:51 PM #1050
Crikeymike's Avatar
Crikeymike's Avatar
Here's the kit builder on my website:
Dobinsons 1" to 3.5" Lift Kit for Toyota 4Runner 4x4 2003-2009 (all options)
Yes, I'd suggest the C59-314 coils with the GS59-220 struts up front, then the C59-327 in the rear with the GS59-701 shocks in the back, plus UCA's.
The C59-327 rear coils are sold out though and it's going to be a few months before they make it to the states again, so there will be a bit of a lead time on those.
Dobinsons 5th Gen T4R Suspension options - from Exit Offroad Crikeymike 5th gen T4Rs 3364 04-16-2024 10:49 AM
Dobinsons 2016 4Runner Trail Build Crikeymike 5th gen T4Rs 43 10-04-2018 12:43 AM
4th Gen Suspension Options/FAQ snivilous 4th Gen T4Rs 0 11-30-2013 10:57 PM
Dobinsons Lift Kit albertomc 4th Gen T4Rs 0 03-01-2013 12:06 PM
