01-27-2020, 12:20 PM
#616
Originally Posted by V8Limited4wd
I recently started to hear some squeaking from my rear passenger side wheel well area. Pretty sure it's from the suspension rubber bushings. Does it mean that the top bolt is on too tight?
Not necessarily. Too loose would mean it has room to move around. Too tight, it wouldn't really budge so shouldn't make noise.
It's not normal for rubber to make any noise to be honest. Be sure to check the top and bottom mounts that they're properly tight.
#1 problem with rear shock installation is if the centering washer isn't in place right and the top nut isn't tightened down properly, then with enough flexing, the stud of the shock manages to touch the mount on the frame, metal on metal.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
01-28-2020, 10:27 AM
#617
I put the top bolt on tight so there shouldn’t be any movement. I noticed the noise this morning when I would go through some bumps in the road. It’s not a loud squeaking noise but definitely coming from that area. Could it be from the shock itself or rear coil then? I’ve ruled out the shock bushings.
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
01-28-2020, 10:45 AM
#618
Yes, it could be the shock (possibly damanged) or the coil (not seated right, excessive movement). You'd have to take the shock off to isolate if it's that.
It's possible for coils to get junk trapped on the lower spring set below the coil, causing metal on metal contact. That might be something to check out, depending where you live and what sort of stuff you've been driving thru.
01-28-2020, 02:05 PM
#619
Hey Mike,
I am currently running c59-350 springs with GS59-220 struts. I have a steel front bumper with winch on my 2008 v8 4wd. I am going to be moving back to a factory front bumper with a low pro bumper and winch which should drop my front end weight a bit. Sitting next to other 4Runners with 3" lifts I feel mine currently sits a tad lower than others at 3" but at the same time feel the 350s are quite stiff. I am looking at going to the 314 or 302 when I move to the lighter set up. Can you give me some advice or input on which spring you would go with?
Im also running JBA UCA.
01-30-2020, 11:59 AM
#620
Hey Guys
For the month of February 2020, Dobinsons is running a free Air Compressor deal with a full suspension kit purchase. Here are the details.
Purchase a full Dobinsons suspension with twin tube struts and shocks, and receive an AC80-3808 Air Compressor free with your order. $145 value
Dobinsons 4x4 Portable 12V High Output Air Compressor Kit with Bag, Hose and Gauge (AC80-3808) | Exit Offroad
Purchase a full Dobinsons suspension with new Monotube (resi or non-resi IMS) struts and shocks, and receive an AC80-3846 Dobinsons Zenith Air Compressor. $325 value
Dobinsons 4x4 Zenith Portable 12V High Output Air Compressor Kit with Bag, Hose and Gauge (AC80-3846) | Exit Offroad
The free item will automatically be added to your order, no coupons or anything required.
Regarding the IMS (non-resi) and MRA (3-way adjustabl w/resi), ETA's are variable on those products, so your order won't ship right away, but you'll still get the deal. You will be emailed an ETA when the order is placed, or can ask up front.
01-30-2020, 12:04 PM
#621
Originally Posted by roadsterboy85
Hey Mike,
Hey man,
Sorry, I didn't see the notification on this post.
I'd suggest you wait and see how it rides when you change the weight as it might not be too bad.
If you do want to change, I'd recommend the C59-302 to maintain a solid 3" of lift.
I've had V8 guys before though run the stronger coils (C59-350 and 352) and like the way it rides, so it comes down to personal taste really.
01-30-2020, 02:50 PM
#622
After listening to the noise a few times, it does sound like metal to metal high pitched squeaking. Going to do some maintenance this weekend so I’ll take a closer look on the lift. Just to make sure, is the rear shock installed correctly?
2004 V8 LIMITED 4WD
01-30-2020, 06:27 PM
#623
Bushing don't look compressed enough. It should meet the outer edge of the washer. If I had to guess. The stud of the shock is touching the metal mount
01-30-2020, 09:34 PM
#624
Thanks for the input! I’ll tighten them up more.
2004 V8 LIMITED 4WD
01-31-2020, 10:53 AM
#625
I'd suggest you take them off and lower the shock to inspect the shaft. It would be shiny metal if it was metal on metal contact. Then you can make sure the centering washer (with the lip) is facing upwards in the mount properly, then tighten it down.
02-03-2020, 01:44 AM
#626
Got it tightened up and the noise is gone! I was checking the rear shock lower mounts and noticed that the paint chipped off and saw some possible rust. Is that type of wear normal?
2004 V8 LIMITED 4WD
02-04-2020, 01:35 PM
#627
Just updated the full kit pages to allow the option to select twin tube, IMS (Internal reservoir Monotube Shocks/Struts, no external resi), or MRA (3-way adjustable w/external resi) in the drop down menus. Not long now until these new struts and shocks start to arrive!!
Dobinsons 1" to 3.5" Lift Kit for Toyota 4Runner 4x4 2003-2009
02-10-2020, 03:24 PM
#628
I'm probably gonna sound clueless, but just to be safe, in my box for my rear shocks for my 2007 4runner (GS59-705), I received two bags, each with a set of 2 bushings and washers marked, "for Toyota Fortuner." Just wanted to check and see if these are in fact to be put to use on my 4runner, or if they're only used on that other vehicle. All the top bushings and washers are already attached on the shock. I've attached a picture if that helps. Thanks!!
02-10-2020, 03:29 PM
#629
It's a good question. You will just use the bushings on the shocks. Match the bushing orientation to the way the original shocks are removed.
The Fortuner ones are for the Toyota Fortuner, a different smaller SUV sold overseas that uses different size bushings and washers.
02-10-2020, 11:30 PM
#630
Originally Posted by Mr.Eeks
Got them installed last week. Here is the one pic I've taken so far. As you can see, Shrockworks front bumper. It's 24" from center of hub to bottom of fender front and back. The ride quality is awesome, though I was coming from a very tired 100k+ miles, stock suspension. Here is what Mike hooked me up with for those that are interested. Highly recommend Mike and Dobinson's, he was super helpful I basically just told him how I use my T4R and what other mods I have done and he will help configure what is just right for you.
C59-314
C59-325
GS59-221
GS59-637
Mr. Eeks, I like your suspension! I couldn't find your signature with the kind of 4runner you have. Is it a V6 or V8 ? I would like this same look but have a V8. How does it ride for you? How do you use this ride?
What ended up being the total lift front/back ? Thanks.
