01-05-2021, 05:03 PM
#946
Originally Posted by jgravlin
CrikeyMike could you help me out on this?
IMS59-50220 with C59-314 front I am good on this setup.
I want about 2 1/2 inches in the rear. Could I put the C59-675V with the IMS59-50701 and be able to accomplish this? On my 2020 4runner I have the IMS59-50701 with the C59-325 but that's supposed to be 2 inch lift I love this setup.
If I use IMS59-50701 with the C59-325 and add a 1/2 inch cornfed spacer on top of coil would I come out better?
This is what you should do for 2.5"
4th gens are heavier in the back than the 5th gens, so the 325's don't lift as much
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
01-15-2021, 10:42 PM
#947
Dobinsons Suspension - 4th Gen Options
Building my next lift to replace my current Radflo setup, I want to maintain the same amount of lift and look. Would the below list do that?
Dobinsons 1″ to 3.5″ MRA Lift Kit for Toyota 4Runner 4×4 2003-2009
C59-354 - With 220-300lbs - 2.5" | Heavy rate coils
MRA59-A221 - MRA 3-way adjustable w/resi monotube (0-2.5" lifts)
C59-701V - 3" long travel, 600-800lbs weight
MRA59-A575 - MRA 3-way adj w/resi monotube long travel 3"+ lifts
Dobinsons Pair of Strut Top Plates (SC59-001)
Dobinsons Extended Rear Swaybar End Link Kit
Dobinsons Adjustable Rear Lower Control Arms
Dobinsons WA59-522K Adjustable Rear Upper Trailing Arms
2005 T4R Silver SR5 V6 4wd with Mods.
01-17-2021, 01:26 PM
#948
Nothing to compare it to.
What lift height do you have now? What are your hub to fender measurements? What front and rear constant accessory weight is on the vehicle?
All that info will be needed to make a comparison.
01-17-2021, 01:48 PM
#949
Measurements: Front is 23.5 hub to fender and Rear 24" hub to fender
Constant Weight:
Radflo 2.5 Coilovers with Radflo 2.5 Long Travel
Plate Steel Front Bumper with Winch
Plate Steel Rear Bumper with Dual Swing Out
Full Set Skids including Gas Tank
Rocksliders
Roof Rack (Mounted RTT for Overland Trips Only)
Rear Storage with Fridge
Current Stance:
01-17-2021, 02:34 PM
#950
Questions about Adj Panhard Bar Vs EIMKeith PCK
Ive been all over, trying to get answers on why I can't have the Dobs Adj Panhard Bar over the EIMKeith PCK?
I figured that's what the Adj Panhard Rod was for. Dobinson recommended it since im doing the LT Kit and doing 3"+ lift. I ordered the Adj Sway Bar links, the Break Line Ext, and the 3" Bumpstop Ext. figured I was all complete.
so what's the big difference over the Adj Panhard Rod and the Correction Kit from EIMKeith?? anyone know? did I make the mistake of ordering the Dobinson Panhard rod??
I appreciate all the input about this if possible.
1996 4Runner (SOLD)
2005 Tundra AC
2010 FJ Cruiser (SOLD)
2019 TRD O/R
2007 V8 Limited
01-17-2021, 08:18 PM
#951
The idea is that you want the panhard closest to level at static height to work best.
When you lift the rig, having a fixed panhard will move the axle to one side...the adjustable panhard bar lets you adjust for that, but won't bring the bar back to level.
Correction kit gives you some adjustment points to bring it to level, and might not need an adjustable bar.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
01-18-2021, 11:58 AM
#952
Constant Weight:
Rocksliders
Current Stance:
OK, so you're at 3.5" front lift now and about 2" in the rear.
You'll need to change to MRA59-A220 since they're a little longer and better suited to the taller lift you're looking for. The 701V rear coils may end up being a little taller in the rear than you are now.
Everything else looks good
01-18-2021, 12:01 PM
#953
You hit the nail on the head.
Adjustable panhard rod lets you center the axle, since it's adjustable.
The panhard rod is also much stronger than stock, so it's not going to flex or deflect like a stock one can under heavy abuse.
The EIMKeith PCK is for "flattening out" the rear panhard rod angle. The Dobinsons panhard rod can still work with this, since it's adjustable.
01-18-2021, 02:45 PM
#954
Thanks for that input.. I had no idea of the PCK until after I ordered the Adj Panhard Bar, and now im stuck with it. Might as well install it. but also going to get the PCK, since its most recommended.. my research was last min, so I didn't get the info I needed in time, because I didn't know I needed more to install. oh well. lol.
1996 4Runner (SOLD)
2005 Tundra AC
2019 TRD O/R
2007 V8 Limited
01-18-2021, 02:48 PM
#955
Thank you as well! -- This makes me feel better about keeping the Adj. Panhard Rod, and just add the PCK. Someone mentioned both is fine, if I was OCD about the alignment. Im not entirely OCD, but id like to be as close to safety and perfection.
You guys are awesome! I appreciate the replies.
1996 4Runner (SOLD)
2005 Tundra AC
2019 TRD O/R
2007 V8 Limited
01-18-2021, 02:50 PM
#956
Real Name: Matt
Real Name: Matt
Rear upper links
@ Crikeymike
I’m looking to replace the upper links in the rear of my 4Runner. Will the WA59-522K adjustable uppers allow pinion adjustment by themselves or will I need upper and lower? I only have budget for upper or lower until my economy is stimulated.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
01-18-2021, 03:13 PM
#957
Originally Posted by Hi-desertT4R
@ Crikeymike
Yes, the uppers will. You can make them longer to raise up the pinion angle.
They're sold out and we don't have an ETA on restock yet. Probably sometime in April or maybe later.
01-18-2021, 06:58 PM
#959
The last time I was doing research on rear springs you quote the follow.
"The 701V with a solid 3" of lift should put you at 25" hub to fender in the rear."
So the 701v will add 1 inch more lift to the rear with 600-800lbs, what if I went with the 677v with 400-600lbs? Will the extra weight level it down below 1 inch? Thx
01-18-2021, 07:04 PM
#960
That would be the only next possible step down option and still a long travel coil, but it won't be a full 1" lower most likely. Dobinsons doesn't make 2" rated long travel coils, they're all based around the 3" mark when weight is on them.
For the weight you're carrying, the 701V is the best spring to handle all that, it's just taller than what you want.
All the 2" rear coils are linear rate and can't be used with long travel shocks, they'll fall out.
Maybe some of the other guys on here running the 677V or 701V can reply with their rear weights and hub to fender measurements for comparison.
