02-06-2023, 10:36 AM
#1201
Originally Posted by dirty monkey
I need help like many others with Springs setup with my Radflo 2.5"
I just recently got them rebuilt, but I want to replace the springs front and rear. They have well over 100k on the springs itself. the fronts are 700lbs and the rears no clue. I have future plans of getting steel front and rear bumpers, with winch on the front. I tow 5k lbs or so with the 4runner. I also, love running fast on trails. Recommendations?
Hey bud. You just have to figure out how much weight is going to be on the rear and what lift height you want, then choose the most appropriate rear coil.
For the front, those are coilover coils most likely, so you'd have to choose matching rear coils from the Dobinsons options, here:
Coilover Coils Archives - Exit Offroad
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
02-06-2023, 03:34 PM
#1202
I understand, can you explain to me the rear coil spring numbers? C59-XXX, going to guess the last three numbers are the lbs
02-06-2023, 05:35 PM
#1203
C for coils, 59 for Toyota, and the numbers after mean nothing. They're just generated number.
02-10-2023, 08:50 PM
#1204
Any word on the C59-849V rear springs?
02-14-2023, 07:08 PM
#1205
Weight?
Hey Mike, looking to get a 3" Dobinsons setup. I'd like to retain a decent ride but still not lose the lift when I go camping and load up. I get that static vs. dynamic weight can be tricky in determining coil rate, but I figure you have the experience to sort this out. How do I weigh my Runner correctly so that I order the appropriate parts? Is it simply find a place I can weigh it empty and then again with all my camping/wheeling gear? I have sliders and a steel front winch mount bumper. Where should I start?
02-14-2023, 10:52 PM
#1206
Hey bud. You just need to add up the weight you've added to it. You have to check with the brands you bought from on what those parts weigh. The bumper and winch for example could be 110lbs or 310lbs, depending on what they are and how they were made. We only loom at the added weight, not the truck weights.
Constant weight is the main concern, not when you load it up here and there for a trip, unless that weight is super excessive.
02-23-2023, 09:02 PM
#1207
Hi Mike,
I've got a 2006 Limited V8 4WD. have decided to go with Dobinsons on the lift but trying to nail down all the options. Mild build planned with front and rear bumpers and winch. Eventually going up to a 34' tire from the 33's. That said, what I'm thinking about is the below:
-C59-352 Front coils
-GS59-220 extended travel front struts for added 1" lift
-C59-327 rear coils
-GS59-705 rear shocks
-Diff drop kit
-Front & Rear lean correction spacers
-Front sway bar relocate
-Extended rear end links
This seem close? My main question is, is the extended travel front a no no without extended travel rear? I'm mainly looking to make sure the truck ends up level and would like the additional front travel.
Thanks!
-Jay
02-24-2023, 10:42 AM
#1208
Originally Posted by Tiller15
Hi Mike,
-C59-327 rear coils
-Diff drop kit
Thanks!
-Jay
Hey Jay,
No, you treat the front and rear separately, so you don't have to match the travel front and rear.
That list of parts looks good. As long as it fits into the weight range of the bumpers you'll be adding. Just don't forget UCA's at that height as well.
03-07-2023, 10:58 AM
#1209
They're due in about a week, but very limited quantities to start with and only made in teal.
3.0″ – Toyota 4Runner 4th Gen – 2003 to 2009 – with 1000LBS+ Constant Load Maximum Flex Coils
Dobinsons C59-849V 3.0" Lift w/1000LBS+ Coil Springs - 4Runner
03-07-2023, 11:14 AM
#1210
Thanks for the info, Mike! That's pretty heavy weight for the rear! I think I should be good with the 749V coils.
06-09-2023, 09:50 AM
#1211
Been a while since we've seen any new photos on here. Throw some up if you've got them!!
06-23-2023, 09:35 AM
#1212
I had picked out a Dobinsons lift before I found this post. I havn't finished but I put it on the ground to check the tire clearance to the front reservoir and I don't have the rear panhard attached. It is a bit taller than I had anticipated but maybe my factory springs were sagging.
06-23-2023, 11:01 AM
#1213
Ifs vehicles grab the ground when you lift then lower them. That's not a realistic way to see what lift you have. It has to be driven and settled to see
06-23-2023, 11:25 AM
#1214
There isn't a lot of compression between full extension and ride height (with the weight currently on it) so scrub isn't going to change it a huge amount. I also have most of the alignment bolts loose so that could be causing all sorts of weirdness. There's still a lot of steps between where it is today and driving anywhere lol.
The Hilux Revo reservoir brackets that my kit came with aren't quite plug and play with my windshield washer reservoir. I had to put it on the ground to make sure that my slightly modified installation wasn't going to cause interference with my over size tires on bone stock 30mm offset rims. Everything looks good so fingers crossed that it will be up and running this weekend or early next week.
07-20-2023, 09:58 AM
#1215
CV59-554K - Outer CV Boot Kit
CV59-557K - Inner CV Boot Kit
Comparison of stock to the Dobinsons CV boots installed
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
