Leaking Upper Ball Joint - Replace UCA's or Just the Ball Joint
Moog ball joint is about $20. Rent the press kit (pay in full and get a full refund when you return it). That being said, it can be a PITA and after doing joints this week I can't imagine doing it with the UCA still on the truck. I don't know how much lift your OME has or what your future plans are but if you're even thinking lift, off-roading, etc, save for aftermarket UCA's. Live with the knock for a bit. It's not do or die.
And if you can't do the work yourself, check around and take the arm and have the joint pressed because it's loads cheaper. I did my joints but I have a guy at a Carquest that'll press my wheel bearings for $20 a pop.
