Old 04-03-2017, 09:30 AM #1
jacksheadache's Avatar
jacksheadache jacksheadache is offline
jacksheadache is on a distinguished road
Replacing the transmission extension housing seal
So I dropped the 4R off at the dealership for a quick oil change and the check list came back with multiple pages of fails. I picked it up with over 200K on it, and plan to get going on most of it here as soon as the weather picks ups, but the one thing that caught me for surprise was a failing "transmission extension housing seal"
After extensive searching here I'm still lost on this one. I see a lot of reference to failing actuators and nightmares about things going south when attempting to repair it. My question is, where is the transmission extension housing seal located? Is this outside of this process? Is it a simple task in comparison? Can anyone point me in the direction of a write up if one exist? Thanks!
Oh also: Dealership wants upwards of $1200 to do this repair. hm?
'07 with a V8
07 Limited 4.7
90 Mustang GT 5.0
jacksheadache is offline   Reply With QuoteReply With Quote
Old 04-03-2017, 03:42 PM #2
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
'07 with a V8
You didn't mention if your ride was a 2x4 or 4x4. But in either case the issue is similar. The dealership is talking about the rear seal at the end of the trans that seals where the rear driveshaft enters the unit. If you have a 2x4, the process to replace the rear seal is fairly simple, you just have to remove the drive shaft, pry the old seal out, install a new seal, and re-install the drive shaft. If you have the 4x4, it is a bit more complicated. The shop manual indicates that the correct procedure to replace the rear seal is to drain and remove the transmission/transfer case assy., and then remove the driveshaft flange, and using a special tool pull the old seal out, and using another special tool install the new seal. Then reinstall the flange, install trans/transfer case back in vehicle, fill with new fluid. I haven't actually done a rear seal on the 4Runner, but I am not sure why one would have to remove the entire trans/transfer case just to replace that seal. Maybe one of the Toyota techs on the forum could shed more info on this.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 04-03-2017, 04:20 PM #3
Thank you for the reply, that answers a few questions. It's a 4x4.
07 Limited 4.7
90 Mustang GT 5.0
ARB torn up seal housing Nate_GB 3rd gen T4Rs 3 12-28-2016 09:41 PM
Rear main seal housing gasket voiddweller Maintenance/Detailing 0 06-11-2015 06:05 PM
Replacing Crank seal SummerallGuard04 3rd gen T4Rs 7 08-19-2012 10:21 AM
What is this bolt? Transmission extension crossmember question bsouthard 3rd gen T4Rs 3 07-06-2012 09:56 AM
Replacing door seal - how to? crooper 4th Gen T4Rs 1 02-28-2011 11:10 PM
