04-04-2017, 06:30 PM
Real Name: Rob
Real Name: Rob
Battery Light started blinking then the car died and now car won't start!
Battery light blinked on and off a couple times last week. Had the battery tested and checked all of the connections for corrosion. Everything was good.
Then yesterday the battery light went on and stayed on. Now I don't have enough juice for it to turn over.
Probably the alternator right?
2006 4Runner SR5 V6 Galactic Grey
Bilstein 5100's with Moog V8 springs all around * BF Goodrich All-Terrain T/A KO2 285/70-17 * 1.5" Hubcentric Wheel Spacers Front and Back * WeatherTech Mats and Cargo Liner * Pioneer AVH-X3600BHS with JVC CSV Series Speakers All Around * Satoshi Grille * LED Interior Lighting * Lots of PlastiDip * RCI Front Skid Plate * Custom Front Bumper by HotMetalFabs * Silver Suicide UCA's * Next up - Custom Rock Sliders * Roof Rack!
04-04-2017, 06:44 PM
Real Name: Skip
Real Name: Skip
Very likely.
2004 Limited V8
04-04-2017, 06:50 PM
check the fuse too, i think its a 7.5 amp fuse.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
04-05-2017, 01:31 AM
Real Name: Rob
Real Name: Rob
Fuse was ok.
Was able to get her to start and got her home. Battery tests at 12.7 volts.
04-05-2017, 05:35 AM
start with a fresh battery, alternator usually make a noise letting you know its dieing.
04-05-2017, 06:45 AM
12.7 battery Voltage while everything's off?
What voltage are you getting while truck is running?
On earlier gens it should be from 13.5 to 15.1 Volts. Outside of that, most likely a bad alternator OR connections to it.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
04-05-2017, 09:59 PM
Test the battery and alternator and go from there.
04-05-2017, 10:25 PM
I had the same problem october 2016, I place the alternator with a toyota REMA and problem solve
2003 4RUNNER LTD V6 4X4
SILVER
