Old 05-15-2018, 03:04 PM #31
ThatguyJZ ThatguyJZ is offline
Real Name: Jim
ThatguyJZ is on a distinguished road
Real Name: Jim
Originally Posted by watson6505 View Post
I have no clue if the Load C vs Load E will have much of a fitment impact, but I like a slightly fuller wheel well.
I'd recommend Load C, they are much lighter and do the job just fine. There is no difference in size between the two. I did however feel a BIG difference going from Load E BFG KO2's down to Load C Duratrac's on my Tacoma.
PS - Is it worth paying $100 to have the springs pre-assembled with the 5100s??
If you do not have air tools, impacts, spring compressors, and want to save 30 min to 1 hour of your lift... Yes.
If you have the tools and the time, then no.
- 2014 Magnetic Grey Metallic Tacoma 4x4 TRD Offroad -
- 2008 Natural White 4Runner SR5 4WD -
- 2001 Black Onyx Lexus IS300 -
ThatguyJZ is offline   Reply With QuoteReply With Quote
Old 08-14-2018, 04:41 AM #32
MRpink's Avatar
MRpink MRpink is offline
MRpink is on a distinguished road
MRpink's Avatar
Not much new to report, but thought I'd share some updates and pics from my recent trip.
-It's been about 1 year and 3 months since I installed the suspension (~15K miles) and no change or sag in lift.
-Rotating the KO2 tires every 6K and they're wearing evenly all around.
-Tried changing the differential fluids and broke a solid 10mm hex, so going to try the chisel and hammer method to break it loose.
Officially no longer a mall crawler. I was scared at first, but it turned into one of my favorite experiences and the beginning of an expensive new hobby...
2007 Limited 4WD V6 | Bilstein 5100 | Wheeler's T1/T12 Springs | FJ Wheels | BFG KO2 | Build Thread
MRpink is offline   Reply With QuoteReply With Quote
Old 08-14-2018, 08:33 AM #33
JeffMerr's Avatar
JeffMerr JeffMerr is offline
JeffMerr is on a distinguished road
JeffMerr's Avatar
Where is that? Looks like my neck of the woods.
2009 Trail Edition
2006 Sport Edition - SOLD
JeffMerr is offline   Reply With QuoteReply With Quote
Old 12-10-2018, 01:58 PM #34
Scaiza Scaiza is offline
Scaiza is on a distinguished road
Originally Posted by MRpink View Post
I wasn't planning on making a thread but the forum has been a huge help to me so hopefully others will find something here useful. Now onto the truck! My current goal is OEM+, this is my daily driver so modifications must be reliable and low maintenance. She'll be on pavement most the time but will see snow and dirt when I'm feeling adventurous.
Current parts:
-OEM All Weather Floor Mats
-Weathertech Cargo Liner (42230)
-Yorkim LEDs
-Bilstein 5100 (set to 0")
-Wheeler's T1 and T12 springs
-Wheeler's 1/4" spacer (front left to correct driver side lean)
-KYB Strut Mount Plates (SM5640)
-FJ wheels ('10-'13)
-BFG KO2 265/70/17 Load Range C (set to 40 psi)
-Hella Optilux 9006 Yellow Bulbs
Parts to be installed:
-Blue Ridge Overland Visor Organizer
Stock with 155K miles and 10 year old suspension.
Current.
I am literally doing almost the same setup as you. Question: You didn't need to go to aftermarket UCA's? I have a 2005 Sport and considered setting the shocks at .85, but then that would merit some UCA's. Your alignment came out great and you have no issues in regards to tires wearing or parts going quicker?
Scaiza is offline   Reply With QuoteReply With Quote
Old 12-10-2018, 06:16 PM #35
MRpink's Avatar
MRpink's Avatar
Almost 2 years and 22K miles with zero issues. With the stock UCA, the alignment shop was able to get the camber and toe within factory specs so no uneven wear or anything.
Old 12-10-2018, 06:21 PM #36
MRpink's Avatar
MRpink's Avatar
Corral Hollow Trail near Bear Valley.
Old 12-10-2018, 06:26 PM #37
That's awesome. I went ahead and bought some new UCA's today anyways since I considered taking the 5100's up to .85, which would set the front closer to 2.5-2.75" I believe. I got the Wheelers T1 and T12 like you, with the 5100's. Can't decide if later I was going to do 255/75r17's or 265/70r17's like yourself.
Old 12-10-2018, 06:41 PM #38
MRpink's Avatar
MRpink's Avatar
Question: How much lift did you achieve going with the Wheelers and 5100's set at zero? Was it exactly what was advertised on Wheelers? 1.75 up front and 1.5 out back?
The before and after measurements are in post #3, but I gained 4” in front and 2.5” in the rear. Keep in mind those numbers are based on my 10 year old (sagging) factory suspension.
I believe the T1 was designed for 0” position, but I would contact wheeler’s directly to inquire about the 0.85 setting.
As for tires, I wanted 255/75 but ultimately went with 265/70 because you can still fit that in the spare tire location.
Old 12-10-2018, 06:49 PM #39
Yeah I actually reached out to them and they told me the .85 was the highest setting on the 5100's. I'm getting some heavy vibrations coming to a quick stop on my current suspension, so that kind of prompted me to just go ahead and buy some new UCA's as well. My numbers should be similar to yours. My Runner has 226K on the odometer so it's super worn out and droopy as well.
All the parts should be coming in within the next two weeks and the install before the New Year. Tires I'll be snatching up sometime next year in the Spring. My Grabbers still have maybe 20K miles on them.
Old 10-11-2019, 01:54 PM #40
YeloSub YeloSub is offline
YeloSub is on a distinguished road
Any updates? You still liking the ride quality with those shocks and springs. Thinking of doing the same. But with a v8 pushing the front down more I might go with the T13 in the rear... like the stock+ look!
YeloSub is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 11:35 AM #41
k_marshall k_marshall is offline
k_marshall is on a distinguished road
I followed your thread. Did the similar setup. used eibach shoks instead of bilstein. Gained about 3.5 to 3.75 in the front. My only issue is stock uca is hitting the coils at full droop. Do you also have the same issue? Thinking of ordering SPC or JBA. But wondering if that would solve the uca hitting the coils issue or would that just help me with alignment.
Update: after 200 miles of driving, front settled in about a little less than 2.5". the rear T12 is still about 23.75" to 24"
k_marshall is offline   Reply With QuoteReply With Quote
Old 02-13-2022, 11:45 PM #42
Blute Blute is offline
Blute is on a distinguished road
Thinking of doing the same as you. You have recent hub-fender measurements? Do you also still have the problem with your UCAs hitting the coil spring at full droop? How has the ride been with this setup?
2006 4Runner Sport V6: Eibach Pro-Truck/Wheeler's T1/T12 lift | JBA UCAs | 265/70R17 BFG KO2 | 5th Gen Brakes | Spidertrax | Clearbra | WeatherTech mats
1998 4Runner SR5 V6 (SOLD): 265/75R16 Duratracs | Taco Whip Antenna Mod | Tundra 199mm Brakes | Tundra TRD Front Coils/OME 890 Rear Coils/Bilstein 5100s | CBI Rear Plate Bumper | Center Console Mod
Blute is offline   Reply With QuoteReply With Quote
Old 02-13-2022, 11:48 PM #43
Good thread, thinking of doing something similar, using either the 5100 or Eibach shocks.
I believe the T1 is a 620 lb spring, correct? Anyone have any thoughts on this heavier than stock spring? How’s the ride for daily driving?
Old 02-18-2023, 08:20 PM #44
Tgore76 Tgore76 is offline
Tgore76 is on a distinguished road
I think stock wheels come in 16 or 17”. Mine are 265/65r17, but I believe I can mount 265/70r17 and gain about 1”
Does larger tires affect anything other than odometer?
Tgore76 is offline   Reply With QuoteReply With Quote
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
