Originally Posted by sr5hi
Are the Toyota Dealers required by law to perform the Recall items like the Accelerator Pedal Modification and Smart Stop ECM update even if the vehicle owner dose not want it to be done?
my 2000 GM truck has the recall still listed concerning the front hub speed sensor rust issue. well I replaced those front hubs and I notified the dealership that the recall should not be still listed for my 2000 truck. they said that I would have to bring in truck to have it cleared.
so when you sell this vehicle , it does show up sometimes and the new owner will have to deal with it.
the recall on my truck was to remove the rust lifting the sensor off the hub a small amount this caused lower volts and NO braking @5MPH.
my hubs were replaced because GM used a grease seal that rusted completely which then caused the bearings to fail [growl sound].
the reason I refused to have GM do this is because the dealerships for some broke the rotors and other brake components some said the FREE recall cost them $1700............
