Old 04-09-2017, 09:30 PM #1
rjb75 rjb75 is offline
rjb75 is on a distinguished road
Power steering pump V8 whine-rebuild
My power steering pump is whining constantly, yet functions properly. Has anyone rebuilt the OEM pump w/the Toyota rebuild kit? Does the bearing in the pump need to be installed with a press or can it be done with hand tools?
Thanks
'16 SR5 Magnetic Gray Metallic
rjb75 is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 10:33 PM #2
Real Name: Skip
Real Name: Skip
Thanks
All of the kits I seen are only the seals, no bearing, I couldn't even find a bearing or kit with the bearing, have you checked to see if the bearing is bad, if you loosen the belt you should be able to feel if there any play on the shaft by grabbing the pulley.
That being said it could be other internal parts that aren't replaceable since the parts aren't readily available and it may still whine if you just put a new bearing and seals in it, if I were you I would just get a new pump or remanufactured one, the seals and a bearing if you could find one would cost you $35 to $50 at least, a remanufactured pumps are from $60 to $125 or so and you get a bit if warranty.
2004 Limited V8
Old 04-09-2017, 11:31 PM #3
tigster562's Avatar
tigster562 tigster562 is offline
tigster562 is on a distinguished road
tigster562's Avatar
My brother in law has the same issue in his runner he had his rebuilt by a shop for only 70 dollars and the problem went away. He was happy he got to keep the original equipment also.
tigster562 is offline   Reply With QuoteReply With Quote
Old 04-10-2017, 05:38 AM #4
justinfetalvero justinfetalvero is offline
justinfetalvero is on a distinguished road
I am interested in this topic. I think I have this same issue. If I am parked and my 4runner is at idle, I turn the wheel back and forth and it whines. Also whines while driving but you can hear it whine the most when you turn the wheel. Is this the issue you are talking about? If so, what exactly should I do to fix this problem? Thanks!
justinfetalvero is offline   Reply With QuoteReply With Quote
Old 04-10-2017, 03:26 PM #5
delucat2 delucat2 is offline
delucat2 is on a distinguished road
I just went through a power steering circus with my Honda Accord. Accords are notorious for air getting into the fluid and turning it into a frothy mess which creates lots of noise. The issue is air getting into the system from leaks on the suction side - someplace between the rack outlet and the pump inlet. Honda was convinced the air was getting past an o-ring used to seal the inlet fitting for the pump. A new larger o-ring was the cure. This repair worked for almost everyone...for a few weeks at most, then then noise would come back. If people got in and moved hoses around the noise would stop...then come back.
If you have air in the fluid - keep reading. If not, the pump is probably where the issue is.
I replaced the o-ring, then a pump. The noise went away each time, then came back.
Being methodical, I looked at the rest of the hoses between the pump and the rack. The reservoir its in the middle. Two hoses remain - the outlet from the rack to the mid point on the reservoir - and the suction line from the pump to the bottom of the reservoir. This line actually sees suction from the pump. Since the lines are black, you're never gonna see a leak. I replaced the line between the pump and the reservoir with $3 of bulk hose and the noise went away..the air stopped getting into the system.
I am convinced the issue here is old hardened low pressure hoses and constant tension hose clamps. The hose hardens and as we go in to do other work, we bump and move things around. Once the hardened hose takes a set, the barb on the reservoir may or may not seal. It obviously does not leak oil out, but air leaking in under negative pressure is another story.
Before you replace anything...try putting a worm drive hose clamps on the hoses on the suction side. You may find the solution is only $10 away.
I will replace the Low pressure hoses with new formed hoses when I get a chance.
Have not had this issue on the 4Runner yet, but this is the approach I'd take first.
delucat2 is offline   Reply With QuoteReply With Quote
Old 04-10-2017, 07:59 PM #6
I was looking at this kit:
Part # 0444653030
Now that you say you've only seen seal kits, the thing that looks like a bearing in the pic is probably the front pump seal. I can get a reman pump but I've heard the aftermarket ones are crap. I guess I can get the OEM one but didn't feel like spending $250+ on something that is a nuisance at best right now.
Mine whines all the time, buts gets quieter as the truck warms up.
Interesting theory. I don't see my fluid foaming up so I'm not sure that air is getting in the system, but anything's possible.
Old 04-10-2017, 09:16 PM #7
CruzadoBlanco's Avatar
CruzadoBlanco CruzadoBlanco is offline
CruzadoBlanco is on a distinguished road
Part # 0444653030
the aftermarket pumps and remans are a joke i went through 2 so far. the first one lasted about 7 or so months then the one i just put in lasted about 1 month. i ordered one off of LKQ vehicle recycling, i hope its an oem pump but i can tell since i havent seen my oem one in almost a year.
2004 white Limited v8 NOW WITH 35s Build Thread -toytec BOSS front set at 1.5" with 2" spacer and Metaltech LT rear -1" 4crawler BL. -Nitro 4.56 gears. -35x12.50r17 treadwright Guarddog MTs. -swaybars removed. -Ebay uniball UCAs. -RCI skids. -E-locker retrofit with 12voltguy panel and harness. -Shrockworks sliders. - body damage and the such
1989 DLX 4runner SAS BUILD
CruzadoBlanco is offline   Reply With QuoteReply With Quote
Power Steering Pump Rebuild 5VZ-FE mmml4 3rd gen T4Rs 11 01-22-2022 09:44 PM
How to Rebuild a Power Steering Pump for $12 Badbob 4th Gen T4Rs 5 04-01-2018 01:26 AM
Rebuild Power Steering Pump willet43 Classic T4Rs 9 08-22-2017 10:03 AM
Engine Whine - mechanic wants to replace my power steering pump at 70k miles Mike2005v8 Maintenance/Detailing 7 05-02-2017 11:48 AM
Power Steering Pump Rebuild Question Badbob Classic T4Rs 3 07-15-2012 10:37 PM
