Old 11-03-2006, 11:34 PM #1
bonedoctor
Guest
Posts: n/a
bonedoctor
Guest
Posts: n/a
Got the dreaded "check engine" + "VSC off" lights
Got that odd combination of "check engine" and "VSC off" etc. lights today. I've got just over 18,000 miles on the odo and nothing new recently except for the TRD exhaust system installed. He did have to do some welding with the system on the vehicle, but it was installed a few days ago and I've put about 50-60 miles on since the installation. I have noticed a distinct "hot brakes" smell coming from the twin tips, but chalked that up to a new system.
So, I went to drive the vehicle today. Started it up and noticed that the lights won't go out. The "CEL" stays lit from when you turn the key to "on", while the VSC off and TRAC lights first will go off, then come back on in about 15 seconds and stay lit. Nothing seems to run "funny", just those persistent lights.
Used the search button and seems to be a common phenomenon. I don't have a code reader, but sounds like an 02 sensor might be the problem.
A few people had mentioned checking for a loose gas cap since apparently this will also trigger the lights. So I check my gas cap and it doesn't seem to be particularly loose, maybe just a little, but oddly when I opened it there was this weird belching, groaning sound that came from the filler tube. I've never heard that before! So thinking a loose cap was the problem, I make sure it's tight and restart the vehicle. The lights do the same thing. Any thoughts?
  Reply With QuoteReply With Quote
Old 11-04-2006, 03:36 AM #2
eightnine's Avatar
eightnine eightnine is offline
eightnine is on a distinguished road
eightnine's Avatar
Originally posted by 4runnab
God, your ****** dumb.
Edited by jharris2 after deleting reported posts
Got the dreaded "check engine" + "VSC off" lights-roomemptyuaintfunny-jpg
1st Generation 1989 4runner Special Edition
eightnine is offline   Reply With QuoteReply With Quote
Old 11-04-2006, 10:33 AM #3
bonedoctor
Guest
Posts: n/a
bonedoctor
Guest
Posts: n/a
WTF, dude?
After "4runnab" learns the difference between "your" and "you're", we'll move on to "it's" and "its" before moving to the very advanced "to", "too" and "two".
"Its to bad your a mo-ron".
One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration MicaBlue03 Problems & Warranty Issues 299 06-05-2023 01:23 PM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
"TRAC OFF" light + "VCS TRAC" light +"check engine" light... arkrunner 3rd gen T4Rs 8 05-29-2009 05:07 PM
Camry '05 NAV causing "check engine"? dareames Engines / Suspension / Wheels / Tires / Audio / Accessories 4 12-30-2005 04:14 PM
Loose gas caps and "check engine" lights Thai Problems & Warranty Issues 0 06-09-2003 11:23 AM
