Originally Posted by jcalkins
Toyota dealership told me my system is leaking and my X Reas and all shocks have to be replaced- I was suggested to ripe out the X Reas system and use all shocks. I am clueless on what to do! My 2010 4 Runner Limited has 105,000 miles, used for commuting over Vail pass, pulling pop up soon to be replaced with a 4500 lb hard shell, some off roading but not crazy stuff, and I love the comfortable ride it offers now and do not need it lifted. What does a girl do?
You can source the shocks from a 5th gen 4Runner off craigslist for under $500. Front 3rd/4th gen Tacoma shocks will also work. I don't suggest the Tacoma rear shocks as they are a bit soft for the 4Runner, even your 5th gen.
The XREAS system can be completely removed without affecting anything else. Replace with standard shocks and you will be good to go. Much cheaper than the XREAS system.
An upgrade would be the Bilstein shocks from any of the TRD OffRoad Tacoma's. Just get Bilstein shocks specific for your 4runner for the rear. They will give you better performance for what you do, give *maybe* a little lift in the front and last longer than the XREAS system did.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
