04-18-2017, 06:27 PM
#16
Originally Posted by DT04R
Holy shit, that $1200 bill for ours looks REALLY good after that post
I literally had the same thoughts after seeing this, LOL.
2008 SPORT V6 4WD
04-18-2017, 09:25 PM
#17
Originally Posted by ghs215
Not sure how you could do that with the upper tabs from the bar going into the box and the 2 arms coming down blocking it from being pulled straight out?
It's been a while since I had to pull an HVAC out of a 4Runner, are those bars not bolted to the main bar like most of the other Toyotas? Usually you can get the long sections off and twist the bar up and pull it towards the driver's side to pull the box out the passenger end.
04-18-2017, 10:19 PM
#18
Nope. Welded. Go figure...
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
04-18-2017, 10:23 PM
#19
Oh, before I forget. Dont forget to put the black ducting (on top of white box) on BEFORE putting the bar back in. We almost got all the wiring harness back on before we realized....lost an hour for that
04-18-2017, 10:38 PM
#20
Real Name: Skip
Real Name: Skip
OOPS!, maybe too much beer by that time contributed to the CRS!!!
2004 Limited V8
04-18-2017, 11:21 PM
#21
I've seen pictures of this job before and it's one my car needs but there is ZERO chance I'm doing it. I lose bolts and break stuff taking apart my dash for head unit and light replacement.
Bravo sir.
In memoriam: 1997 SR5 4WD, 350k miles (RIP)
2005 V8 4WD Limited daily/only driver, ask me about: OME 885/90000 front, 895/60004 rear, ARB bumper, Warn 9000xd winch, RockyRoad Supersliders (pending install...grrrrr), BFG T/A KO2 255/75/17 (32" pizza cutters), Spixertrax, Pioneer AVIC NEX, VSC/Trac delete switch, secondary air bypass, CB w/ firestik, etc
04-19-2017, 12:01 AM
#22
Not to sidetrack your thread too much, but quick question for you people that are experienced with the AC issues:
I just tried using my AC for I think the first time since purchasing it last fall, and the AC light just blinked at me and didn't produce any cool air. I read that it may just be a $27 relay I need to replace, is this generally what my symptoms mean? Or what might the signs be that I would have to replace all this expensive mess?
2003 Sport Edition 4x4 V8 with 170k+. 3" spacer lift on Billsteins w/stock coils, SPC UCA's, rear Airlift bags, Flowmaster, 285/70/17 Falken Wildpeak AT3W on 17x9 Dick Cepek rims, LED Interior swap, grill-mounted light bar, Thule roof bars/bike racks with rear lights, Kenwood stereo with Sony speakers
04-19-2017, 01:16 AM
#23
I think maybe you can swap your horn relay to see if it fixes it. If it is, then you can buy the new relay
Air 4rceRunner One, 04 Sr5
04-19-2017, 01:43 PM
#24
Check the FSM.
Blinking of A/C indicator - Compressor lock sensor circuit - AC-42
This sensor sends 4 pulses par engine revolution to the A/C amplifier. If the ratio of the compressor speed divided by the engine speed is smaller than a predetermined value, the A/C amplifier turns the compressor off, and the indicator flashes at about 1 sec. intervals.
DTC No. 22
Detection Item
All conditions below are detected for 3 sec. or more.
(a) Engine speed: 450 rpm or more.
(b) Ratio between engine and compressor speed deviates 20 % or more in comparison with normal operation.
Trouble Area
Cooler compressor assembly
• Compressor drive belt
• Compressor lock sensor
• Harness or connector between compressor locksensor and A/C amplifier
• A/C amplifier
04-19-2017, 02:04 PM
#25
Check the FSM.
DTC No. 22
Detection Item
Trouble Area
• A/C amplifier
How does one pull the codes for the A/C system when the light is blinking? Is it through Techstream or by some other means?
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
04-19-2017, 08:23 PM
#26
@ simple
Depends on if you broke the actuator arm or not... the actuator is bolted to the right side of the box next to the ECM and such.
Is that something I can look at with it in the dash? I took a quick look, and nothing was overly apparent. Thanks
04-19-2017, 08:47 PM
#27
Replacing Re-circulation Actuator
Once you get the actuator off you can stick a mirror in there and look at the door and actuator and see if you just got lucky and popped it out of it's track or if you broke it (if it's broken, it's a bit more complicated to fix).
04-20-2017, 03:51 PM
#28
Check the FSM.Blinking of A/C indicator - Compressor lock sensor circuit - AC-42
Does this mean the compressor is locked up and not spinning (broken inside?)
04-21-2017, 03:08 AM
#29
low gas could also cause the blinking light. throw some guages on the hi and loside ac ports, i bet they are very low. that also implies that you have a leak in the system
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
04-22-2017, 08:59 PM
#30
You're the man! I popped it off its track. It was a PITA, but I got it back on with a butter knife. Thanks again
