04-26-2017, 02:26 PM
Anybody running 34x10.50 BFG KO2's here??
I'm highly considering running this tire when I install my lift. Anybody here running them and if so post some pics please.
How bad are your issues with rubbing??
04-26-2017, 04:16 PM
34x10.5 BFG AT KO2, anyone run them?
They are pretty much the same size as 255/80 17.
04-26-2017, 05:25 PM
id probably recommend a 1" body lift to help clear the tires, you can set your suspension to 2" of lift to keep it low if you want to, and you are gonna have to do a body mount chop and cut the fenders some along with flatten the pinch weld. you also need to have a decent aftermarket UCA and have the alignment tech set as much caster as possible to pull the wheel forward in the wheel well. Your cutting and bashing wont have to be as much as mine was for my 35x12.50s but its gonna be very similar.
2004 white Limited v8 NOW WITH 35s Build Thread -toytec BOSS front set at 1.5" with 2" spacer and Metaltech LT rear -1" 4crawler BL. -Nitro 4.56 gears. -35x12.50r17 treadwright Guarddog MTs. -swaybars removed. -Ebay uniball UCAs. -RCI skids. -E-locker retrofit with 12voltguy panel and harness. -Shrockworks sliders. - body damage and the such
1989 DLX 4runner SAS BUILD
04-26-2017, 09:00 PM
Real Name: Mark
Real Name: Mark
Considering them next as well, but the $250 price difference over 285/70 may not be worth it.
my list:
34x10.50 or 285/70 KO2 or Ridge Grap in 285/70
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
04-26-2017, 09:22 PM
I was going to run them, then I came across a smoking deal on some 255/80 ST Maxx. Anyway, for the 255's I had to push the fender liners forward and re-drill the holes plus trim the bottom of the front bumper a little. They did contact the top of the fender well on a hard bottom-out but the 6112's and Wheeler's super bumps fixed that for now, a 1" BL is in the plans. They also will very slightly rub the rear fender liners when stuffed but it's very slight, YMMV. So far, I got away without doing a BMC or flattening the pinch weld but those BFG's are a tad taller. Overall the tall skinnies have been great over everything and they fit good without trimming a bunch of stuff. The downside is, should you ever destroy a tire, a replacement may be somewhat hard to find.
That being said, my next tire will probably be a 285/75/17 (true 34" tire).
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
04-26-2017, 11:26 PM
I'm probably going to give the 34x10.50's a shot. This will be 90% driven on the highway so no worries with stuffing tires offroading. Will keep y'all updated.
05-25-2017, 09:45 AM
Here you go... installed yesterday with 5100's set at 2.5. Very minimal rubbing.
05-25-2017, 10:26 AM
Real Name: Mark
Real Name: Mark
got a few more shots? from front or rear? Looks good!
'04 Sport V8
05-25-2017, 10:50 AM
looking to do this with the 285/75 ridge grapplers.. More pics of clearances please..
Looks great!
06-02-2017, 09:43 AM
What are your overall impressions the last week? Please show us more pictures!
2009 SR5 4WD V6-WKO Sliders, FJ 17' wheels
06-02-2017, 12:54 PM
I sent you a visitor message. Did you get it? Tires have been great. Slight rubbing on UCA at full lock after alignment but I haven't had to trim anything. Will post more pics when I can.
06-02-2017, 02:13 PM
I didn't even think to look there. I'm not to forum savvy, I was checking my PM inbox. Thank you for the info. Like everyone else eagerly awaiting some more photos. Your 4Runner is too cool to not see more of!
06-10-2017, 10:23 AM
Here's a few pics. I've been real pleased with them.
06-10-2017, 10:25 AM
Another... forum will only let me upload one per post. Sux
06-10-2017, 07:33 PM
