Old 07-22-2017, 01:31 AM #61
emcdemc emcdemc is offline
emcdemc is on a distinguished road
Originally Posted by TripleTS_T4R View Post
I am thinking about finally installing the USB this weekend so i will attempt to have pictures to go with the parts list to make things more smooth in the transition. Stay posted.
Yes, please share.
emcdemc is offline   Reply With QuoteReply With Quote
Old 07-24-2017, 06:25 PM #62
For SiriusXM, looks like you can use this one instead if you prefer no-USB interface: Vais GSR-101
I also found these USB adapters, which might work and have Prime shipping:
1: https://smile.amazon.com/Goliton-fem...dp/B01H1A4L06/
2: https://smile.amazon.com/Vehicle-Aud...dp/B00WW52OC8/
Someone can correct me if I'm wrong.
Old 07-28-2017, 01:36 AM #63
I finally completed install, including SiriusXM. I went with GSR-101 instead of GSR-001. Turns out the GSR-101 has USB out and in so you don't have to sacrifice other USB functionality. GSR-001 only has USB out (to radio).
I mounted BT mic on steering wheel column. Works great.
Now I want BT buttons for my steering wheel!
When nav comes down in price, I'll surely add it.
Old 07-28-2017, 09:48 AM #64
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
Originally Posted by emcdemc View Post
I finally completed install, including SiriusXM. I went with GSR-101 instead of 001. Turns out the 101 has usb out and in so you don't have to sacrifice other USB functionality.
Cool, where did you add the Sirius antenna? When you added it, did a satellite radio icon show up in the source menu?
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 07-28-2017, 10:33 AM #65
I installed antenna in rear a long time ago for a portable radio. Pretty easy.
Yes. See here, they even have a video: http://www.vaistech.com/product/gsr-101/
It works exactly as shown.
EDIT: And here's a pic from my install: https://i.imgur.com/k35cZWv.jpg
Old 07-29-2017, 08:03 PM #66
Originally Posted by Southernbike View Post
For navigation you will need Toyota Part No.: PT296-12160
You will also need the brackets to attach the navigation module to the radio- PT228-18160
I just ordered the NAV from these guys: OEM QNG-BE2808 Navigation Module Toyota Include Wiring for 180.00 ? - Radio / Navigation & Parts
I paid extra to use Paypal and Fedex. So if they are fraudulent, I should be covered.
Now I need to hunt down the brackets. Still trying to figure out if and how I can switch to North America maps. Looks like it is update through USB, see page 158: http://www.billswebspace.com/OMSADG0702D.pdf
EDIT: I cancelled order until I confirm with a dealer that they can update maps at a reasonable cost.
Old 07-29-2017, 09:03 PM #67
simple's Avatar
simple's Avatar
I was able to drill holes in my existing brackets. Its not ideal or clean, but it works.
Old 07-30-2017, 02:28 PM #68
Cool, I may try same.
Old 07-31-2017, 02:39 AM #69
simple's Avatar
simple's Avatar
For the love of Zeus, after weeks of working around, I got my camera to work. I would like to do a write up in a build thread or something, but this Photobucket crap has really messed with my motivation to do so.
Anyway, I used the the harness that was posted here earlier with the fuses and stuff. I got mine on eBay, I think from the same seller as autoharnesshouse. It probably would have worked with my old harness, but this solved the trying to tap 12v power to the camera problem. One big issue is the plug wouldn't fit in my radio without some persuasion from a razor and dremel.
Lastly, I had to add a reverse wire to my 24pin connector. The harness I purchased came with one that has the pin and everything. I just inserted it into my connector.
I ended up tapping that red/yellow wire in the driver door sill and that made the camera work flawlessly. It was in the center of the loom toward the bottom. Overall, I'm not pleased with the camera. It's better than nothing, but it's not as wide view as I had hoped, it's off center, and I can't see my bumper which helps me gauge distance. I probably can't do anything about the off center, but may look into different camera options.
I wired up everything with quick disconnects instead of butte connectors so I could easily replace components in the future if they fail. But damn what a PITA this whole adventure has been.
Here's pics of the wire I tapped in the driver door sill. I had to cut away a little tape on both ends to give me room to work/manipulate the wire.
PT546-00160 - 2016+ Scion Head Unit-img_9234-jpg  PT546-00160 - 2016+ Scion Head Unit-img_9232-jpg
Old 08-06-2017, 07:07 AM #70
poovs poovs is offline
poovs is on a distinguished road
Originally Posted by rossiski View Post
I've tried running a 12v signal from the rear reverse tail light to the 2nd pin in the 24 pin harness. I measured 12v was indeed arriving only upon shifting into reverse. Didn't flip the screen to another "source", i.e. like the RCA input. I honestly don't think Pin 2 is the input for a reverse signal as a result of my testing. Could there be some versions of this 2016 Scion radio that don't have reverse camera capability?
Edit: I agree about your thought that the radio shouldn't care if the camera is running 12v or 6v. Those that have the 6v camera are running power from the radio (6v). I'm not getting power from the radio but from an accessory 12v source that is definitely supplying 12v to the camera. The camera is outputting about 1.5v from the RCA plug when the 12v accessory source is powered. It's the radio not recognizing when reverse is engaged (and not knowing to switch input to the RCA source.)
Did you get this working?
poovs is offline   Reply With QuoteReply With Quote
Old 08-06-2017, 09:30 AM #71
wmflyfisher's Avatar
wmflyfisher wmflyfisher is offline
wmflyfisher is on a distinguished road
For those that want to retain the factory 6v backup camera as I did in my 05 limited I used the Beat Sonic BC-1. Worked perfect with my Kenwood DDX and didn't have to install a new camera or run a new wire. Not the cheapest part but effective.
https://www.sonicelectronix.com/item...saAs2jEALw_wcB
wmflyfisher is offline   Reply With QuoteReply With Quote
Old 08-08-2017, 12:23 PM #72
rossiski rossiski is offline
rossiski is on a distinguished road
Nope. Almost to the point of giving up.
Sent from my Pixel using Tapatalk
rossiski is offline   Reply With QuoteReply With Quote
Old 08-12-2017, 01:32 PM #73
Bummer... I should have done more research on this myself... apparently there is not a "plug-and-play" wiring harness for the "UrbanRunner" package (I have a 2009 Trail Edition)...
I ordered all the parts I needed from the parts list in this thread, then pulled the existing deck, and lo and behold, the connectors don't mate up.
I now have to decide whether or not to cut & splice
Old 08-18-2017, 04:17 PM #74
rbendes rbendes is offline
rbendes is on a distinguished road
Maybe a dumb question but... If you don't care about hands free calling BUT you want to stream music via Bluetooth do you have to get the (PT546-00120-MC) Bluetooth Microphone Kit ?
rbendes is offline   Reply With QuoteReply With Quote
Old 08-18-2017, 04:35 PM #75
simple's Avatar
simple's Avatar
On older scion radio's the answer was yes. You needed the mic to enable Bluetooth. Haven't tested it here, but my assumption is you need the mic.
WTB Toyota/Scion Bluetooth microphone cable PT546-NU160/PT546-74120-mc trublucali For Sale: T4R Items 0 09-02-2016 08:45 PM
Scion Head Unit? PAULUNM 4th Gen T4Rs 7 12-17-2008 09:12 AM
Convert JBL Head unit to Scion Unit ttman Engines / Suspension / Wheels / Tires / Audio / Accessories 9 08-19-2008 05:48 PM
scion head unit.. haddix 3rd gen T4Rs 1 06-23-2008 08:21 AM
Scion Head Unit sbbamafan Engines / Suspension / Wheels / Tires / Audio / Accessories 14 11-29-2006 09:08 PM
