06-02-2017, 08:19 PM
Body Mount Chop??
I wasn't sure where to post this, but seeing that it pertains to my 4th Gen I'll start here. Would it be ok for me to chop my body mounts and not get to welding the plate on for a little while? I wouldn't be wheeling or anything, just maybe some street driving. I'm not sure if there could be structural issues and wanted to see what you guys thought or to see if anyone has run with "open" body mounts. Thanks!
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
06-02-2017, 08:29 PM
I wouldn't do it. The plate which will keep the structure of the mount strong. I body chopped mine and had a chance to look at it (not drive) without the plate. Nope. I never want to drive without welding the plate.
There is no place like 127.0.0.1
06-02-2017, 11:16 PM
Real Name: Mark
Real Name: Mark
Been driving mine not welded for almost 4 years. Works just fine. I will weld some in when I do some cam tab gussets.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
06-03-2017, 12:09 AM
You'll be fine without the plate for a while. Plenty of people run no plate. I would use some spray paint to protect the bare metal from the elements though. Don't want that thing rusting while you wait to do the plate and seal it up.
04 4Runner limited V8 -- OME lift, LR UCA, Diff breather mod, 275/70/17 BFG KO2, Spidertrax, Trail Gear sliders
06-03-2017, 01:54 AM
Running unplated atm. I do plan to get it plated/welded at some point
06-03-2017, 09:05 AM
Real Name: Justin
Real Name: Justin
Ive debated this back and forth recently as I want to do the body chop sometime soon. Ill get around to welding it eventually but I am gonna run it without the plate for a good while.
2007 Limited V6
ICON 2.5 Ext. RR CDC
MetalTech Stage 5 LT
SCS SR8 Dark Matte Bronze 17x8.5
06-03-2017, 11:46 PM
Thanks guys! Next time I have the grinder out I'll chop the body mounts. I'll probably weld plates on in a month or so.
06-05-2017, 08:01 AM
Cut mine off over a year ago, I got the plate to cover them up but think I might end up chopping more so I left it open and trim more every once in a while. Plenty of people running open body mount tabs with no issues. They appear to be shaped that way for manufacturing purposes, the extra reinforcement is not needed.
06-06-2017, 09:06 PM
@ blackoutt
@ NinjaOne
@ sparky
Could you guys share a picture of your chopped mounts when you get a chance? Thanks!
06-06-2017, 09:09 PM
@ blackoutt
@ NinjaOne
@ sparky
I rub just a tad still on the corner at full lock when compressed. I'm going to trim slightly more and find somebody to plate it
06-06-2017, 09:37 PM
It's ideal to reinforce the area with a plate, that being said I'm a hypocrite and lazy as I've been running over a year with it chopped and not plated and wheelin' fairly hard. So... plate it preferably, but not the end of the world if you don't?
06-07-2017, 09:04 AM
I got to see a few body mount chops the past weekend at an offroad event, most were plated off, a couple were not.. it seems many people round off that back edge and actually weld 2 pieces of steel with a seem in the middle and grind it down to a round edge then paint it to make it look good and give the most clearance from the tire.
Planning on doing this myself in the coming weeks. But i will need someone to weld it..
06-07-2017, 10:56 AM
My baby chop that gets me by on these tires with minimal rubbing. I intend to cut more and plate it but not on high priority of things to do.
10-02-2017, 12:29 PM
Metaltech has $20 3/16" plates bent and ready for welding back together if you choose...I have them myself and look to be doing this body-mount chop soon.
https://www.metaltech4x4.com/4th-gen...ount-chop-kit/
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
10-02-2017, 05:25 PM
I had mine installed ASAP because I want to ready to trail at any moment.
Sent from my SM-G930P using Tapatalk
2006 4.7L V8 SE
Build Thread Colorado
