Old 07-06-2018, 11:56 PM #46
JeffMerr's Avatar
JeffMerr JeffMerr is offline
JeffMerr is on a distinguished road
JeffMerr's Avatar
265/70/17 isn't that much bigger. In my opinion this should have been the stock size as it looks a lot better than 265/65/17. You won't need any trimming and probably won't even have to do anything to the liners. When I moved up to 265/70/17 I think I lost about 1mpg.
2009 Trail Edition
2006 Sport Edition - SOLD
JeffMerr is offline   Reply With QuoteReply With Quote
Old 07-11-2018, 09:42 PM #47
OliviasDad's Avatar
OliviasDad OliviasDad is offline
OliviasDad is on a distinguished road
OliviasDad's Avatar
Just added a set of these Wildpeaks (265/70/17), wondering what others have set their PSI levels at? Mine are currently set at 38psi, should I adjust?
OliviasDad is offline   Reply With QuoteReply With Quote
Old 07-12-2018, 01:47 PM #48
bpchura's Avatar
bpchura bpchura is offline
Real Name: Brendan Chura
bpchura is on a distinguished road
bpchura's Avatar
I personally run 32-34 all around. Just passed over 10k miles and no noticeable wear yet.....
2007 SR5 4WD - Toytec Ultimate 3" Front Coilovers, Boss Extended Travel Rear Shocks and Springs, 285/70/17 Falken Wildpeak A/T3W, Spidertrax, Body Mount Chop, JBA UCA, White Knuckle Sliders
bpchura is offline   Reply With QuoteReply With Quote
Old 07-23-2018, 12:00 PM #49
bigguy02's Avatar
bigguy02 bigguy02 is offline
bigguy02 is on a distinguished road
bigguy02's Avatar
265/70/17 is now the stock size tire. I really wish som one would make a 265/75/17 to put on these.
bigguy02 is offline   Reply With QuoteReply With Quote
Old 07-23-2018, 10:23 PM #50
vonguido vonguido is offline
vonguido is on a distinguished road
Has anyone run the 285/70/17 load E on the stock rims?
05' V8 4Runner Limited
Reason for the question. I just purchased a OME(886/895)/Bilstein(5100's) lift kit and will be running an ARB front winch bumper. However I intend to keep my stock rims for the time being until I can get the TRD rims or Methods/SCS.
I'm curious about any rubbing that may occur whether that be body mount or UCA's, etc
vonguido is offline   Reply With QuoteReply With Quote
Old 07-25-2018, 08:28 PM #51
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
Just got mine installed today
I ended up going with the stock sized 265/65r17 tires. I went back and forth several times but after looking at a lot of pics these tires would in my opinion have looked stuffed with a 265/70r17 and the front probably would have had some slight rubbing issues. I think it turned out great though!
Falken Wildpeak AT3W: initial impressions-img_3265-jpg  Falken Wildpeak AT3W: initial impressions-img_3263-jpg  Falken Wildpeak AT3W: initial impressions-img_3264-jpg  Falken Wildpeak AT3W: initial impressions-img_3266-jpg
Johns06yota is offline   Reply With QuoteReply With Quote
Old 12-12-2018, 06:15 PM #52
Scaiza Scaiza is offline
Scaiza is on a distinguished road
I've been doing some heavy tire research and I'm thinking these are the way to go, but just want some input to make sure they'd work.
Lift is on the way. The setup will be as follows: Wheelers T1 Front with 5100's set to .85 (2.5-2.75" I assume), and Wheelers T12 rear. Also going on the girl is a pair of Wulf Suspension UCA's.
Taking that lift into consideration, do you guys think the 265/70r17's should fit on the stock rim without rubbing or modification?
2005 Sport V8 4WD
Thanks.
Scaiza is offline   Reply With QuoteReply With Quote
Old 12-12-2018, 08:51 PM #53
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
They will fit just fine.
techno is offline   Reply With QuoteReply With Quote
Old 12-12-2018, 08:56 PM #54
BendRunner BendRunner is offline
BendRunner will become famous soon enough BendRunner will become famous soon enough
icon stage 2, 285/70/17 on a stock rim. Will I run into any issues with the stock rims? Obviously trimming will be needed as well as BMC.
BendRunner is offline   Reply With QuoteReply With Quote
Old 12-12-2018, 09:06 PM #55
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
2005 Sport V8 4WD
Thanks.
Wheel offset seems to be the biggest factor in whether the tires rub. On mine with 265/70/17 I needed to move the wheel liners in the front, and remove the mud flaps because I installed them on wheels with. +1mm offset. It’s really no big deal at all once you look carefully to determine where the rub spots are. With stock rims though, you should be ok.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 12-13-2018, 08:54 AM #56
I see. I appreciate the response. I had a set of Falken Rocky Mountains on my runner and I loved them. I don't have any tools nor do I know anyone in the area who could help me out as far as trimming the fender/making any other mods to accommodate for the tires. The other route I was thinking was the 255/75r17 Yokohama Geolandar AT G015. I'd love to be able to throw a pair of tires on the stock rim without having to modify anything.
Old 12-13-2018, 10:54 AM #57
AdmiralAugbar's Avatar
AdmiralAugbar AdmiralAugbar is offline
AdmiralAugbar is on a distinguished road
I've been running 275/70/18 on my 2006 for about 23,000 miles, I love everything about these tires except the weight. Only come in LT E rated for the size I wanted, but their performance in rain, snow, regular and offroad driving has just been great. Still have tons of tread left. Great tire at a great price.
2006 Limited V8 - 1.25" wheel spacers | 275/70/18 LT Falken A/T3W | Bilstein 5100s | OME 885 springs in front | FJ springs in rear | LED light bar | Rhino Rack X-Tray
AdmiralAugbar is offline   Reply With QuoteReply With Quote
Old 12-14-2018, 07:44 AM #58
Just so you know, for the 265/70 at least, you really don’t need any special tools, or have to cut anything if you have any rubbing. The mud flaps are screwed on, as are the wheel well liners. There are threads that discuss moving the front of the liners for added clearance, but essentially all you are doing is taking out the screws, moving the plastic liner forward an inch or so, then screw it back in place in the new location. There are metal clips that the screws thread into that you move also, but that’s about it. A drill is handy to drill new holes, but since it’s plastic, you could probably just punch new ones with an awl, or a nail, or similar pointed tool. Most threads I’ve seen using 265/70 didn’t require any mods though with stock wheels, unless they were running spacers to change the offset, or wheels with different offset like I have. I was wanting a more aggressive stance without sticking out way pay the body, which is why I chose the offset I did. It took me about a half hour to completely eliminate all rubbing by determining where the rubbing was, then moving the offending plastic. Super easy, and well worth it in the end.
Old 12-14-2018, 10:54 AM #59
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
im really likein these tires, got in E but ride is smooth & quiet.
chaz is offline   Reply With QuoteReply With Quote
Old 12-14-2018, 11:19 AM #60
dcTR4 dcTR4 is offline
dcTR4 is on a distinguished road
Got these in the P rating and absolutely love them!
Sent from my SM-N950U1 using Tapatalk
dcTR4 is offline   Reply With QuoteReply With Quote
New Falken Wildpeak M/T Konkordmusk 3rd gen T4Rs 16 01-06-2020 01:06 PM
Falken Wildpeak AT3W or BFG AT/KO2 jmferg 3rd gen T4Rs 81 12-15-2018 01:23 AM
Falken Wildpeak AT3w VS Pathfinder AT poser Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-07-2017 05:59 PM
Falken wildpeak at3 Rudeboy706 3rd gen T4Rs 6 05-30-2017 06:49 PM
