01-04-2018, 10:01 PM
#16
Originally Posted by jzchen
The sensors only transmit when tires are revolving no? So the system is not checking the spare unless you mount it? So if you replace the faulty one with the spare, (whose battery should last a lot longer since it is not actively transmitting), and the light goes off, you've found the culprit.
Not true, this tpms system looks for 5 sensors including the spare, they don't need to be spinning to read air pressure.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
01-05-2018, 04:03 AM
#17
Real Name: Steven
Real Name: Steven
As Lightfreak stated, the TPMS sensors are always active. The Psi, tire temp, TPMS battery voltage, ID, location etc is always on if the key is on.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
01-05-2018, 12:40 PM
#18
Originally Posted by MightyP
Try a different tire shop. Walk with the guy who tests the sensors. It's possible (I guess) they all went bad at the same time. Also, shouldn't be more than about $50/sensor with all the labor. $700 is probably more than the dealership would charge you.
Thanks for the replies guys.
Will the ATEQ Quickset also identify which sensor is bad?
I highly doubt that 5 sensors went out in the course of 3 weeks. Possible, but highly unlikely.
07-13-2018, 12:40 PM
#19
Bumping this thread because I have the same TPMS issue and have had it since I picked up the car New a year ago.
I find it so strange that the light only begins to flash on long drives (>3-hrs). Does anyone have an explaintion for this?
07-13-2018, 03:41 PM
#20
TPMS sensor batteries typically last 10 years. The batteries are not replaceable, they are sealed within the unit.
Different sensor types for alloy vs steel wheels.
An Autel TPMS scanner can read the condition of the sensor battery.
With the 4th Gen turning 10 y/o, I suspect most all our original sensor batteries are fading off to the sunset.
After 10 years, plan to replacing the sensors with your next set of tires, and programmed to the ECU.
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
02-16-2019, 12:10 AM
#21
my original tpms just died ... 15 years been a good run...
02-20-2019, 08:07 PM
#22
Recently my TPMS light went on solid. The shop said I had a nail in the tire and patched it. Light is still on. Went back and we checked the air pressure on all 4 tires plus the spare and the light is still on. After reading this thread, I'll assume that one, or all, of my sensors are dead or dying.
Question, I recently bought wheels/tires from a 2018 T4R owner who is upgrading all his wheels. If I put these "new" wheels/tires on my 07, will the TPMS system read the sensors from these newer wheels? Or, is the new set of wheels/tires not compatible with my 07 system so I'll either have to live with the light on all the time or disable the system?
4Runner Noob
2007 SR5 V6
02-20-2019, 10:11 PM
#23
Real Name: Skip
Real Name: Skip
I can't say on the 2018, I looked at Denso sensors and their website had no listing for the 2018 yet, but the 2016 4Runner uses the same sensor as the 2007, the 2017 however has a different part number, but the frequency is the same (315MHz) and also the pressure range as the 2007 and 2016, not sure what the difference is.
That being said I still think that the 20018 may work IF they use the same frequency, pressure range, etc,....but they would have to be programmed or cloned to the TPMS ECU, because the sensors you have now are programmed and they would have to be deleted or the 2018 sensors cloned to their programming.
To do the programming or cloning you would need a TPMS programming tool to do it.
2004 Limited V8
03-04-2019, 08:51 PM
#24
Well I ordered the Denso 550-0103 sensors for my 5th gen rims, and the ATEQ Quickset tool. Now I just need some tires. Hopefully I'll be getting some this week. I'll report back once I get everything together.
2005 4R V8 4x
03-04-2019, 09:55 PM
#25
Yeah, Denso 550-0103 for alloy wheels, and 550-0102 have the shorter stem, for the steel wheels.
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
03-05-2019, 12:38 AM
#26
Originally Posted by Trumpet
Wow, thanks for that link. Tired of looking at the blinking cluster light.. Been like that for years.
2004 4Runner 2wd - 200k+ Miles - Original Owner
12-19-2019, 05:00 PM
#27
My 2007 has had the solid TPMS light on for a year or so. I decided that while I was getting new tires, might as well replace those sensors. After the tire/sensor swap the light was still on solid and the tire shop said my OBDII connector was broken and couldn't make them work. So I took it to a trusted shop and the OBDII scans fine, they reset the code the TPMS had been throwing and the light is now off (YEA!!!!). Now the problem is if I lower the pressure in any of the 5 tires the light never comes back on or flashes. WTF???? Went back to the tire shop and their scanner (held next to sensor, not attached to OBDII) shows each sensor working showing the actual pressure ( we lowered one to 15psi). But still no light or warning. Wondering if they put the wrong kind of sensor in, some other reset/reprogramming needs to be done to make the light come on when the psi goes south. I can live with it not working but did I just pay 200$ to have the light turn off?
