Old 06-19-2017, 01:22 PM #1
Elan_'s Avatar
Elan_ Elan_ is offline
Elan_ is on a distinguished road
Elan_'s Avatar
Exclamation 2006 V8 Nearly zero power? Starts fine, idles fine.
Started my truck up to go to work this morning and about two or three minutes into my commute I lost nearly all power. Was less noticeable on level road but when I started climbing a significant hill about 5 mph was the maximum speed I could get, pedal to the floor. 30 mph was about the max I could get on even a slight incline. Check engine lights was on when I looked at the dash.
Pulled over and turned off the truck for about 30 seconds. Truck started fine again, idled fine. Full power after restart for only about 20 seconds then lost it again. I returned home and parked it for about 4 hours then drove it to my mechanic. Still no power. Mechanic not home so I went back home. On the trip home the problem seems to have went away. Parked it for another 2 hours and drove again, no power problem. Issue seems to have gone away. Check engine light still on. Don't have a reader.
Any ideas what might cause this sort of thing?
2006 Limited - Silver | Toytec 3/2 Bilstein 5100s | Total Chaos UCAs | 275/70/18 KO2s
Elan_ is offline   Reply With QuoteReply With Quote
Old 06-19-2017, 01:55 PM #2
skott skott is offline
Real Name: Scott
skott is on a distinguished road
Real Name: Scott
Sounds like it's in limp mode. I bet your check engine light is on for the air injection system. Search the forums for it...there are no less than 1 million threads about it. Sounds like a bypass kit is in your future.
skott is offline   Reply With QuoteReply With Quote
Old 06-19-2017, 05:08 PM #3
T4RNightHawk's Avatar
T4RNightHawk T4RNightHawk is offline
Real Name: Will
T4RNightHawk is on a distinguished road
Real Name: Will
Second what Skott said. Wanna say its the pre 06 models that had problems with this.
T4RNightHawk's Build Thread 2008 V8 4Runner Limited Black
T4RNightHawk is offline   Reply With QuoteReply With Quote
Old 06-19-2017, 07:11 PM #4
Elan_'s Avatar
Elan_'s Avatar
That seems like it. Picked up a code reader from walmart and it's P2440, Secondary Air Injection System Switching Valve Stuck Open Bank 1.
Limp mode seems to have cured itself so I'm not sure if this is going to be a problem that needs addressing.
Old 06-19-2017, 07:18 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
The valve/s most likely became unstuck, the valve/s get stuck because a bit/s of the plastic impeller in the air pump has broken off and gets stuck in the valve/s, if it became unstuck, you're lucky because that usually doesn't happen often, BUT err on the side of caution and GET the bypass and install it and you'll never have to worry about this happening again!!!
2004 Limited V8
4runner idles fine but sputters when accelerating WFB 3rd gen T4Rs 3 11-21-2015 02:15 AM
Help! 4Runner starts fine but begines to run rough once warmed up chd2001 4th Gen T4Rs 1 04-23-2014 10:07 PM
1992 4runner 3.0 cranks forever, finnaly starts, then starts fine timcarl450 Classic T4Rs 2 03-26-2013 12:56 AM
86 SR5 22RE Idles fine but surges off idle to full throttle Arnie19 Classic T4Rs 6 03-22-2013 11:05 PM
