Originally Posted by lightfreak
With the car in park, can you rev past 2500rpm?
Pull the ETCS fuse and look for corroded contacts, it's located in engine bay fuse box, check the contacts in the fuse box as well.
Does your cruise control still work fine? The cruise control module is tied into the same ETCS fuse.
Thanks for the reply.
Yes in park currently I can rev past 2500RPM and cruise control works perfect.
When the acceleration issue happens I'll check to see if it revs in park past 2500rpm and also try the cruise control. It happens randomly so let's see when it decides to act up. I'll also check the fuse box and ECTS fuse for corrosion.
2004 4Runner V6 2WD
-Moog FJ front springs -Stock FJ rear springs
-KYB GR2 shocks all around
-1/4 Toytec front spacers
