Originally Posted by robguitargod1
I'm well versed in inner (diff side) boot replacement:
How to: Replacing inner CV boots
Nothing is damaged, but I wanted to clean the joint thoroughly and there's no way to do that if the joint won't come off the axle.
The replacement boot comes with a replacement c-clip so I'm pretty sure there's one holding the joint on. I believe it retains the joint the same way the inner half is retained in the diff.
Factory Reboot kit comes with two clips. One snap-ring for the inner CV Joint and a C-Clip for the splined end that goes into the differential. I'm not aware of any other clips in the kits (I never have left over parts when I do them and I haven't had to take apart the outer assembly yet.)
Post Note-
Not sure honestly, TIS doesn't show any way to remove the Tulip. Even the components section just shows it as an assembly at that end. Usually you take a tube and squeeze the grease into the gap between the tulip and the housing to "flush" it out. If you have contaminants in the tulip grease like dirt/abrasive particles it's probably done at that point. If you're dead set on cleaning it, I'd scoop out as much grease as possible and just hose the crap out of it with a couple can's of brake clean, then jam as much grease as you can in there. Though in all my years and all the years my coworkers have been changing them out, "flushing" the grease has worked fine.
