Originally Posted by ClubberLang9
I've noticed on all 4th generation 4runners the passenger side manifold rust out and clog that first catalytic converter and makes the Bank One sensor to go off making the check engine light come on well the easy way I figure it out the fix that in cheapest way and it's not a spark plug fouler it's drilling a small hole above that catalytic converter and spraying seafoam directly into it and that will clean all the rust that's out in there. then I've noticed the back window mine rusted-out the clamps and it kick sideways well when I straighten the back out it was going to put a part in there to keep it from falling down I bent down to grab the part in the window shattered all over me when I wasn't even touching it so now I'm replacing it and I didn't realize that the new window tracks doesn't come with Hardware nor the motor for the window so now I don't know what size the bolt is that holds the cable spool into the motor because I don't have any hardware plus it's already installed and I do not want to take it back apart again because I had to almost destroy the motor to get the first one out track system that is Penny know anyone knows what size bolt that goes into that cable spool for the tracks that goes into the window motor into the center let me know not to mention I had one hell of a time getting that spool to fit into that motor because it was off just a hair so I had to take a file and file out one of the sides of the spool so it would fit over the square nut but I've been over this vehicle head to toe I've got 6 amplifiers two batteries I ran a 0 gauge cable through the frame system to the back underneath to run that second battery to run everything and I've got lights in every possible place legal Ones white lights cuz they're the only ones in New York state that you can have under your vehicle not only are they under my vehicle they are in every possible spot you would need if you were doing some sort of work on it and to go camping like a bug-out vehicle I put a three-quarter inch piece of plywood up into the ceiling with a air mattress on top of it with a cable system in Motors back in the rear quarter panels that when you push a button the plywood drops down but you have to take the headrest off the seats put the seat all the way forward then all the way back then take the seat headrest stick them in the whole tree hold pre drilled holes into a two-by-four like a tree stand Christmas tree stand almost so you could support the plywood you stick it up underneath the plywood and then blow up the air mattress so you can sleep and then I have a projector on my rear liftgate so when it goes up the projector comes out of the liftgate and you could watch a 25-foot movie and it's all done nicely not to mention I took out my spare tire cut a hole in the back floor put a subfloor in there like it was like your spare tire goes on the inside but instead of the spare tire I put 312 and I'll make it the fires hidden with a piece of three-quarter inch plexiglass over-the-top so it's sealed then I have four 6x9 5 6 inch woofers that are three ways tweeters 24 inch TV in the front and that will clean all the rust that's out in there. then I've noticed the back window mine rusted out the clamps and it kicks sideways well when I straightened it back out and was going to put a part in there to keep it from falling down I've been down to grab the park in the window shattered all over me when I wasn't even touching it so now I'm replacing it and I didn't realize that the new window tracks doesn't come with Hardware nor the motor for the window so now I don't know what size the bolt is that holds the cable spool into the motor because I don't have any hardware plus it's already installed and I do not want to take it back apart again because I had to almost destroy the motor to get the first one out track system that is funny no anyone knows what size bolt that goes into the cable spool for the tracks that goes into the window motor into the center let me know not to mention I had one hell of a time getting a spool to fit into that motor because it was off just a hair so I had to take a file and file out one of the sides of the spool so it would fit over the square knot but I've been over this vehicle head to tell I've got 60 amplifiers two batteries I ran a 0 gauge cable through the frame system to the back underneath to run that second battery to run everything and I've got lights in every possible place legal ones white lights cuz they're the only ones in New York state that you can have under your vehicle and I'd only got the under my vehicle there every possible spot you would need if you were doing some sort of work on it and to go camping like a bug out vehicle I put a three-quarter inch piece of plywood up into the ceiling with a air mattress on top of it with the cable system and Motors back in the rear quarter panels that when you push a button the plywood drops down but you have to take the headrest off the seats put the sea all the way Ford then all the way back then take the seat headrest take a minute to Freehold pre drilled holes into a two-by-four like a tree stand or Christmas tree stand on most so you could support the plywood you stick it up underneath the plywood and then blow up the air mattress so you can sleep and then I have a projector on my rear liftgate so when it goes up the projector comes out of the liftgate and you can watch it 25 ft movie and it's all done nicely not to mention I took out my spare tire cut a hole in the back floor put a subfloor in there like it was like your spare tire goes on the inside but instead of the spare tire I put 312 s and I may have the fires hidden with a piece of three-quarter inch plexiglass over-the-top so what sealed that I have for six by nines 5/6 inch woofers that are three ways tweeters 24 inch TV in the front they checked out it's my bug out sorry about if anything is sounds weird it's because I'm using voice to text cuz I'm tired of texting
I only made it about 1/3 of the way through your post before giving up because it so hard to read without having punctuation marks, paragraphs, changing the subject in mid-sentence etc., if I were you I would edit it and add some minimum punctuation, so more members will read it!!
I'm very old but even I know that you can add punctuation marks when voice texting, you might want to read up on how to do it.
