Old 03-28-2019, 02:05 PM #31
Dirtrider216 Dirtrider216 is offline
Dirtrider216 will become famous soon enough
Just placed my order for all my headlight goodies. I will be doing a D2s 4.0 low beam retrofit with TRS Profile Hi-lens led high beams and all will be painted black
I will update with pictures when I receive everything
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
Dirtrider216 is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 08:23 PM #32
Finished up my headlight retrofit- this was my first time doing one and I’m very happy with it overall
I bought $80 tyc replacement headlight housing units for “parts” mainly just the lenses since mine were badly fogged over but I also ended up having to grab the plastic nut that the one of the adjustment screws goes into
I used gray retro rubber to seal the lights back up and then put some waterproof silicone Around the outside to be extra sure. I haven’t been through a car wash yet but heavy rain has caused no water to condense inside the headlights
For the build parts I used morimoto D2s 4.0 projectors and and trs profile hi lens led units to go in my high beam slot and I have the lights wired to use the D2s for low beam and then the D2s high beam and profile hi lens for my high beams when I turn them on
I used krylon matte black spray paint and I was rather liberal with it.
To mount the projectors I used a lightwerkz metal mounting bracket and the profile hi lens threads fit right through the hole for the bulb.
I did have to dremel the projector shroud from the oem housing considerably to get it so that the light would aim properly and in retrospect it would have been easier to buy separate shrouds to use instead
2006 limited v8 4wd
Old 09-09-2019, 12:43 AM #33
Little bit of TLC for my grom so I can get it put up on craigslist for sale soon
Gotta fund an AR build and 35s somehow Dubnasty216 build thread
2006 limited v8 4wd
Old 11-13-2019, 09:59 AM #34
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
In terms of dremeling out the housing, is that to give clearance for the 3" lens compared to the stock 2.5" projector? Separate shroud just to cover up the dremeling, or??
Looks mint
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 11:28 AM #35
Looks mint
Yeah the back side of the black painted housing was contacting the projector lens when I was trying to aim. (thankfully I decided to make sure everything would aim BEFORE I sealed the housing up) but if I had bought shrouds I feel that I would have been able to just make a more open cut and use the shroud to mask the hole a little better
2006 limited v8 4wd
Old 11-13-2019, 12:06 PM #36
apohl17's Avatar
apohl17's Avatar
Makes sense. Good to know!
IG @apohl17
Old 03-02-2020, 04:05 AM #37
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
I'm assuming you dremeled the projector hole on the shroud open for more clearance. How much did you have to take off? Doesn't seem like too much? Mine are hitting the shroud hard for upward adjustment, I'm gonna have to take a decent chunk out I think.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 04:23 PM #38
4Runner is officially sold and it may be a while before I get another one.... On to new adventures with 40mpg
2006 limited v8 4wd
Old 05-12-2020, 08:23 AM #39
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
whatd ya get? good luck
hinmo24t is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 03:18 PM #40
2017 Honda Civic hatchback
A year of rotations coming up and needed something better than 12.4 mpg
2006 limited v8 4wd
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
Bamatoy's not so clever build thread title...thread Bamatoy 4th Gen T4Rs 7 06-27-2017 03:33 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
