03-28-2019, 02:05 PM
#31
Just placed my order for all my headlight goodies. I will be doing a D2s 4.0 low beam retrofit with TRS Profile Hi-lens led high beams and all will be painted black
I will update with pictures when I receive everything
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
07-20-2019, 08:23 PM
#32
Finished up my headlight retrofit- this was my first time doing one and I’m very happy with it overall
I bought $80 tyc replacement headlight housing units for “parts” mainly just the lenses since mine were badly fogged over but I also ended up having to grab the plastic nut that the one of the adjustment screws goes into
I used gray retro rubber to seal the lights back up and then put some waterproof silicone Around the outside to be extra sure. I haven’t been through a car wash yet but heavy rain has caused no water to condense inside the headlights
For the build parts I used morimoto D2s 4.0 projectors and and trs profile hi lens led units to go in my high beam slot and I have the lights wired to use the D2s for low beam and then the D2s high beam and profile hi lens for my high beams when I turn them on
I used krylon matte black spray paint and I was rather liberal with it.
To mount the projectors I used a lightwerkz metal mounting bracket and the profile hi lens threads fit right through the hole for the bulb.
I did have to dremel the projector shroud from the oem housing considerably to get it so that the light would aim properly and in retrospect it would have been easier to buy separate shrouds to use instead
2006 limited v8 4wd
09-09-2019, 12:43 AM
#33
Little bit of TLC for my grom so I can get it put up on craigslist for sale soon
Gotta fund an AR build and 35s somehow
2006 limited v8 4wd
11-13-2019, 09:59 AM
#34
Real Name: The Native Explorer
In terms of dremeling out the housing, is that to give clearance for the 3" lens compared to the stock 2.5" projector? Separate shroud just to cover up the dremeling, or??
Looks mint
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
11-13-2019, 11:28 AM
#35
Looks mint
Yeah the back side of the black painted housing was contacting the projector lens when I was trying to aim. (thankfully I decided to make sure everything would aim BEFORE I sealed the housing up) but if I had bought shrouds I feel that I would have been able to just make a more open cut and use the shroud to mask the hole a little better
2006 limited v8 4wd
11-13-2019, 12:06 PM
#36
Makes sense. Good to know!
IG @apohl17
03-02-2020, 04:05 AM
#37
I'm assuming you dremeled the projector hole on the shroud open for more clearance. How much did you have to take off? Doesn't seem like too much? Mine are hitting the shroud hard for upward adjustment, I'm gonna have to take a decent chunk out I think.
2006 4Runner Sport Edition V8 4WD
05-11-2020, 04:23 PM
#38
4Runner is officially sold and it may be a while before I get another one.... On to new adventures with 40mpg
2006 limited v8 4wd
05-12-2020, 08:23 AM
#39
whatd ya get? good luck
05-13-2020, 03:18 PM
#40
2017 Honda Civic hatchback
A year of rotations coming up and needed something better than 12.4 mpg
2006 limited v8 4wd
