07-04-2017, 01:49 AM
UCAS do I need them
Just put 265/70/17 Duratracks on my '04 V8 (filled the wheel wells great and zero rubbing at lockout in reverse) and my next step is OME's with XREAS delete. My question is will upgraded UCAS do anything for this build and if so what? This will be a daily driver that will get into some great Colorado back country.
07-04-2017, 02:02 AM
It really depends on how your alignment turns out (you did do an alignment after putting on larger tires, right?). If you run out of camber that'd be a good reason to change out the upper control arms.
07-04-2017, 10:28 AM
Get some SPC UCA's, they look great and offer additional adjustments if you need them
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
07-04-2017, 11:11 AM
I can't seem to get a straight answer on it. For a daily driver highway queen and a 3" suspension lift, some folks say just do it, but others say they've done dozens of T4R suspension lifts and are able to get perfect alignment without new UCAs. So I just don't know anymore.
Sent from my SM-G935V using Tapatalk
07-04-2017, 11:28 AM
Normally caster decreases the more you lift our suspensions. If your alignment is in specification and you are comfortable with the handling then you don't need aftermarket caster correcting UCAs.
Some people don't like the way a car with low caster handles, some folks don't mind low caster.
3" of lift is a rough estimate for when the car will be around the spec limit and/or the handling performance threshold (varies person to person).
Edit: Also, additional caster brings the wheel forward in the wheel well, which will decrease the chance of the wheels rubbing on the body mount.
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines// http://www.toyota-4runner.org/4th-ge...ld-thread.html
07-04-2017, 01:53 PM
I put SPC UCA's on this time, the two times I lifted before I stayed stock. Three reasons:
1) More adjustability if you need it.
2) I read if you go to wider tires they can rub against the stock UCA's.
3) I read aftermarket UCA's can allow better articulation, wheel travel.
An example about articulation, I had a Tacoma with the TRD Baja 2" lift kit. TRD designed it to work with stock UCA's but they specifically noted in order to get the full travel out of the shocks upgraded UCA's are needed.
I cheaped out before and didn't upgrade, did fine keeping the lifts to about 2", there was some difficulty getting the caster in specs. As said above some people don't care if caster isn't in specs because it doesn't cause abnormal tire wear but does cause a floaty/wandering feel to the steering at high speeds.
This time on the '08 I figured I'd upgrade, boost it up closer to 3" lift and be able to adjust the caster to what feels the most stable at highway speeds.
07-04-2017, 07:23 PM
Real Name: Chris
Real Name: Chris
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
07-04-2017, 08:37 PM
Real Name: Michael
Real Name: Michael
What does daily driver have to do with it? Do you want factory alignment numbers and handling characteristics or not? You can answer your own question. Install your lift and get it aligned. Math facts should provide a straight answer. No?
2005 V8 Sport Edition l Toytec Boss l SPC LR UCA
07-04-2017, 10:28 PM
A straight answer re: whether UCAs are needed for a 3" suspension lift to retain spec alignment. Some say Yes, some say No.
07-04-2017, 10:44 PM
No...no lift was ever stated and with that under 3in ..no
07-04-2017, 10:59 PM
I'm just under 3 inch of lift and despite my caster at 3.3. It still wander quit a bit on the freeway. In fact, you'll constantly correct the steering wheel. Quite frustrating. Buy everyone's rig is different so trial and error. Best of luck!
2022 Toyota 4Runner TRD OFF ROAD PREMIUM
07-05-2017, 07:13 AM
I did it and am glad I did.
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
07-05-2017, 07:35 AM
Real Name: Mark
Real Name: Mark
You definitely HAVE to have UCA's! Without them the wheels would fall over!
I went with stock for a year, put some SPC's on and ride changed to the better, smoother. Glad I finally bought some.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
07-05-2017, 01:17 PM
Real Name: Ron
Real Name: Ron
Like others have said, it's a question if you like how it drives after the lift. Aftermarket UCA's will allow increased caster and better stability on the highway, but it's personal taste as to how much that matters to you.
For me, I didn't like the way the vehicle wandered with 2.5" of lift and about 2.7 degrees of caster (still within spec). I put on SPC UCA's, bumped the caster to 4 deg, and it drives great.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
