Old 07-06-2017, 10:17 PM #1
J-Roc's Avatar
J-Roc J-Roc is offline
Real Name: J
J-Roc will become famous soon enough J-Roc will become famous soon enough
J-Roc's Avatar
Real Name: J
Leaking Oil Pan 05' 4WD Removal Help
I have done some searching and haven't had any luck and I'm sure this has been covered before.
Had my truck in the shop today for an oil leak. They tell me it's the oil pan and dip stick holder.
Just wondering if anyone can direct me in the right direction for the oil pan removal process.
Does anyone have a thread/write up on this?
Seems like a day project in the garage, but don't want to run into anything unexpected.
Also having a hard time paying the shop 5 hrs labour for something that sounds simple enough to do.
Thanks
2013 Blizzard Pearl Ltd/14’+Tail Light Swap/Anytime Backup Cam/275-55-20 Wildpeaks/TailAsTurn/Triton V3 Switchback Fronts/5100’s/1” Eibach Rear Coils/CaliRaised Ditch Pods&Brackets
Sold-2005 V8 Dorado Gold Pearl Ltd
Retired-1996 Evergreen Pearl Ltd
J-Roc is offline   Reply With QuoteReply With Quote
Old 07-06-2017, 11:37 PM #2
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
The v8 has two pans. One small stamped metal one that is were the oil pick up and drain plug is located. The larger one is aluminum and covers the complete bottom of the engine. The motor has to be pulled to get it off. Not worth it in my opinion.
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 07-07-2017, 12:33 AM #3
Jefe13 Jefe13 is offline
Jefe13 is on a distinguished road
Get a second opinion. Quite possible it's just the o-ring for the dipstick tube. I have a few of these come through my shop and I've never seen the upper pan leak. Maybe valve cover gaskets, but not the oil pans. Mine V8 has 212k on it and both pans are bone dry.
Jefe13 is offline   Reply With QuoteReply With Quote
Old 07-07-2017, 02:55 PM #4
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
The motor does not have to be pulled to get it off. I have taken mine off by myself in a day. To get it off you have to remove the front differential and the steering rack and remove both front CV axles. After you have that stuff off, there are about 16 bolts that have to come off, some from INSIDE the smaller oil pan that comes off the bottom of the larger oil pan. This is not a 2 hour job.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 07-07-2017, 03:00 PM #5
J-Roc's Avatar
Real Name: J
J-Roc's Avatar
Real Name: J
Exactly what I was looking for! Thanks very much.
Just needed a good idea of the process it would take. Prob just let the shop take care of it.
Time is money, especially your own.
Old 08-13-2017, 12:15 PM #6
J-Roc's Avatar
Real Name: J
J-Roc's Avatar
Real Name: J
Anyone have a part number for the Dipstick Tube and O ring?
Took a better look and that seems to be the problem. I would like to replace the whole tube itself as it is getting rusty.
Thanks
Old 08-13-2017, 06:28 PM #7
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
[96721-19010] O-Ring
[11452-50190] Dipstick Tube
Edit- Corrected the Part Number
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 08-13-2017, 07:54 PM #8
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
[11452-31030] Dipstick Tube
With all due respect, I believe that dip stick isn't for the 2005 V8, according to my search the part number would be.....
OIL TUBE - TOYOTA (11452-50190)
2004 Limited V8
Old 08-13-2017, 08:01 PM #9
Looks like the part is 11452-50160 I got for a 2UZ-FE, but the 190 at the end could be a superceded part, so I'll take your word for that.
I had snagged a V6 Dipstick part number by accident. Sorry about that, thanks for catching that.
No worries, I'd rather be called on being wrong than have the poor guy order the wrong part.
Edit-
Actually I'm not sure what the different between the two is... Village Toyota Parts shows both part numbers when I cross-checked it against Partsouq... I don't think there's a difference in dipsticks between 2WD and 4WD, nor should there be a difference between VVTi and Non-VVTi as they don't bolt up differently... So why there's a 11452-50160 & 11452-50190 part number for the same item I don't know...
http://parts.villagetoyota.com/showA...rimLevel=14102
Old 08-13-2017, 08:19 PM #10
Real Name: Skip
Real Name: Skip
Edit-
2005 TOYOTA 4Runner SR-5 4700CC 32-VALVE DOHC EFI, AUTOMATIC 5-SPEED CYLINDER BLOCK
When I did my search I got part number 11452-50160 for my 2004 V8 but part number 11452-50190 for the 2005 V8, not sure what the difference is but I would suggest the OP submit his VIN number when purchasing the part so the supplier can verify which is the correct one for the 2005.
2004 Limited V8
Old 08-13-2017, 09:45 PM #11
I second that, I put a 2005 4Runner in for VillageToyotaParts website and they give both dipsticks as an option, so I'd have them run the VIN to be sure.
Old 05-04-2024, 08:48 AM #12
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
I'm so glad I found this thread, because I was also wondering how much effort it takes to remove the oil pan in order to replace the FIPG. Given that I have a deadline, I'm going to run a thicker oil until such time when I can devote a whole day to this project. Maybe wait till one of my frog CV axle boot is leaking, at that time do this project all at once.
As I was staring up at it yesterday, I was thinking do I really have to move the front axle tube and this thread confirmed it.
I am so impressed with this engine that even at 400,000 miles, the only leak I have is the leaky oil pan seal. Not the o-ring, but the actual seal. I slowed it way down by tightening all of the bolts on the perimeter but that is not a real fix. Additionally, I don't like a leaky engine.
Just wanted to say thanks for the information on this thread.
Sent from my SM-G981V using Tapatalk
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Rear differential leaking housing leaking? Schwooby Classic T4Rs 5 07-01-2014 06:43 PM
Is my CV leaking? bgibbs11 4th Gen T4Rs 3 03-09-2014 10:48 PM
97 SR5 V6 Toy leaking oil hallj22 3rd gen T4Rs 4 10-14-2012 12:06 AM
What is leaking? wutagoalie 4th Gen T4Rs 21 06-27-2012 09:31 PM
'99 SR5 Leaking Oil mcolliga 3rd gen T4Rs 2 01-31-2011 01:14 PM
