Originally Posted by RDOOGZ89
I had popped off the tire because one of the shims on the brake pads somehow had been pushed out of position (off topic of the point of this thread, but has anyone had this happen?). That was easily fixed. But, when i started looking around i noticed some nasty corrosion on a UCA joint (not sure if that is what it is really called). I will attached a picture.
I need some advice. Can i take a wire brush to this spot? Is there anything kind of lube or rust preventative that should be used? I will eventually have to change the UCA when install the lift, but that wont happen for a while ($$$).
**no idea why the pictures came out upside down.
If the UCAs are that rusted, I'm wondering how the undercarriage looks..?
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines//
http://www.toyota-4runner.org/4th-ge...ld-thread.html
