Old 07-26-2017, 05:07 PM #1
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
Steering Wheel Shake
I saw this problem in the Gen 3 section and I have the exact same problem with my 2004 Sport V6.
I've noticed it from day one and am wondering if it is getting worse since a tire roto...Any other Gen 4 guys ever hear of, or experience, a similar problem, know what is causing it? Thanks for any comments or insight.
Edit to say it only happens when going over a bump, more pronounced at highway speeds, otherwise smooth going.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 07-26-2017, 08:57 PM #2
4runsport's Avatar
4runsport 4runsport is offline
4runsport is an unknown quantity at this point
4runsport's Avatar
Yes and I think I have narrowed mine down to bad shocks in the front end. My XREAS system is dead and the truck bounced like an old cadillac. Somewhere in that thread I read someone suggested that because the shock is not holding the tire down to the road it causes the steering wheel to shake. I am currently working on buying new shocks to hopefully fix the issue.
2002 Toyota 4Runner Sport/ Toytec 3" lift
Front: OME-883 OME-90004 Rear: OME-891 OME-60027
Toytec Front Diff Drop Kit. Rola roof rack.
Alpine head & amp/ Polk sub
4runsport is offline   Reply With QuoteReply With Quote
Old 07-26-2017, 09:42 PM #3
JLRSR5's Avatar
JLRSR5 JLRSR5 is offline
JLRSR5 is on a distinguished road
JLRSR5's Avatar
I had this actually today. So originally after my 3" lift and 33 tires plus aftermarket method nv wheels I had a very minor shake from 48-60mph. Not enough to bother me.
Well today I had my tires balanced and everything went to heck. I had horrible steering wheel shake around the same speeds. Went from about a 15% shake before tire balance to a 55% shake after.
Took the truck back to discount tire and had them rebalance the tires as well as install some hubcentric rings for my method nv's and solved the issue. I think mine was a wheel balance issue more so than the hubcentric rings bc I did not have them before today and it wasn't a bad shake.
So all that backstory for: Could be a tire out of balance.
1999 4runner SR5 Imperial Jade Mica: SOLD
2007 4runner Sport Galactic Grey: 20% tint front windows+windshield strip, 35% tint rear widows. OME 884 front coils w/ Adj. Bilstein 5100 set at "0", and Toytec Superflex rear coils w/ Bilstein 5100's. 285/70r17 Nitto Ridge Grappler "C load", Method NV's 17x8.5.
JLRSR5 is offline   Reply With QuoteReply With Quote
Old 07-27-2017, 10:17 AM #4
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks, I have to replace mine also and am working on sourcing the parts. I think I may have an installer. But, I'd sure hate to go through all that and still have the problem.
Regards, sport2004
Old 07-27-2017, 10:23 AM #5
ladywolf ladywolf is offline
Real Name: Kristen
ladywolf is on a distinguished road
Real Name: Kristen
this is probably a dumb thought but theres not a steering stabilizer on the front-end is there?
ladywolf is offline   Reply With QuoteReply With Quote
Old 07-27-2017, 10:32 AM #6
bombventure's Avatar
bombventure bombventure is offline
Real Name: Jared
bombventure is on a distinguished road
Real Name: Jared
Just had our 3" lift installed last Friday, and had some minor shaking at about 50mph+, Monday the wife took it in to get it re-torqued while I was at work, told the guy about it and he fixed it. Tire was off balance, no more shake now. Hopefully it's just something minor like that! Best of luck!
bombventure is offline   Reply With QuoteReply With Quote
Old 07-27-2017, 10:45 AM #7
superman3043's Avatar
superman3043 superman3043 is offline
Real Name: PD
superman3043 will become famous soon enough superman3043 will become famous soon enough
Real Name: PD
Try this. Easy fix. Worked like a charm and never came back after blue Loctite.
-PD
2005 V8 SR5 4WD Natural White
My Build Thread
My "Rally Rocket" 2017 WRX
superman3043 is offline   Reply With QuoteReply With Quote
Old 07-27-2017, 11:19 AM #8
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
I don't think independent front suspension needs one (but I don't know why). It's usually only found on trucks with solid front axles.
There are probably dozens of things that could cause the wheel to shake. Unbalanced tires or wheels, uneven brake rotor, sticky CV joint, loose suspension parts, bad shocks, etc.
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 07-27-2017, 11:21 AM #9
Real Name: Kristen
Real Name: Kristen
It was just a thought. 99% of the time thats the cause of the DW in Jeeps.
Old 11-17-2021, 08:09 PM #10
Hhgv2354 Hhgv2354 is offline
Hhgv2354 is on a distinguished road
Steering wheel Wobble at 40+
2006 4runner limited (always in 4wd model)
Recently installed a 3 inch lift (ome springs and Bilstein shocks) 17" wheels 33" bf all terrain tires with balance beads ( shipped mounted and balanced)
Steering wheel wobbles at 40+ mph
New CV axles were installed, and it still wobbles ( they were bad anyway)
I'm lost ... Any help would me much appreciated.
Hhgv2354 is offline   Reply With QuoteReply With Quote
Old 11-18-2021, 07:26 AM #11
Real Name: PD
Real Name: PD
How's your steering and suspension components? It sounds like tire balance to me, but if you've ruled that out, check your tie rods (outer and inner) and your control arm ball joints and bushings (upper and lower). Hope that helps.
-PD
My Build Thread
Old 11-18-2021, 12:24 PM #12
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
+1 on the above. Tie rods, inner and outer, mine were shot. That helped a lot. The other portion was crappy alignment after bouncing off some rocks.
Having your tires shipped mounted and balanced also doesn't say much, could be a much quicker and cheaper attempt prior to throwing more parts at it.
aemravan is offline   Reply With QuoteReply With Quote
Steering Wheel Shake stever1000 3rd gen T4Rs 52 10-30-2021 03:04 PM
Steering wheel and car shake Duke562 5th gen T4Rs 16 10-08-2016 09:42 AM
Possible fix for the steering wheel shake 68ChargerJMP 3rd gen T4Rs 3 01-08-2016 03:56 PM
Steering Wheel Shake nvestor88 3rd gen T4Rs 10 07-13-2014 01:40 PM
Steering wheel shake before and after delucat2 4th Gen T4Rs 1 10-28-2013 01:38 PM
