Originally Posted by luke87gt
Wait, what? What do you mean "exploded"?
I was bleeding the system after 5th gen caliper upgrade and when I was pushing the brake pedal while my friend was bleeding rear left caliper all I could hear from the back was Fu..... When I stepped out to see what's up I found him covered in brake fluid and complete rear end was coated in brake fluid as well.
Line that goes between the gas tank and rear axle corroded just before fitting to rubber brake hose, to the point we're it would not hold excessive pressure during bleeding procedure.
Good thing is, universal lines are easy to install if you got new fittings and brake line tools.
2005 V6 LTD 186k
