Old 08-07-2017, 12:38 PM #1
El_Jefe_83 El_Jefe_83 is offline
Real Name: Jeff
El_Jefe_83 is on a distinguished road
Real Name: Jeff
Help! NO START NO Crank Issue
Good morning All,
I am having a No start, no crank, no click issue. Am very close to admitting defeat and taking it in.
I have had my 4 runner for 3 years with out a single issue up until this point.
On Friday I dropped it off with the wife and took my Land cruiser, got a call that night, it wont start.
I trouble shooted /tried to jump it and went back on Saturday with tools and for testing.
Symptoms: Turn the key, power turns on, when I turn the key nothing. Not even a click. Lights in the truck do not dim.
What I checked
-I pulled the starter, took it to be tested, it works fine. (have never had a hard starting problem.)
-Checked the voltage on the battery and was at 12.4 I imagine since I had tried numerous times to start it had drained slightly. I took the battery out of my cruiser and still did not start. Put 4runner battery in my cruiser and it started. Battery Possibility, eliminated.
-Checked fuses, starter relay, ignition fuse, STA fuse pretty much all fuses.
I read through the different threads, and could not come up with any similar symptoms.
Any help would be appreciated.
El_Jefe_83 is offline   Reply With QuoteReply With Quote
Old 08-07-2017, 01:30 PM #2
28.'s Avatar
28. 28. is offline
28. is on a distinguished road
28. 28. is offline
28.'s Avatar
I was gonna say maybe fuel pump but if you have a good starter AND battery, maybe bad ignition switch due to fact it won't even turn... Don't think our keys have chips in them..
Sent from my VS988 using Tapatalk
04 4runner Sport Edition V8 4WD // X-REAS removed // Bilstein 5100s // Fj Cruiser coils // Interior LEDs // gshadow325 12V charger mod // Undercarriage LEDs // Back-up lighting // onboard 12v air compressor // 255/75/17 Duratracs // Homemade load bars // Smittybilt roof rack(when needed)
2016 T4R Trail Edition
2017 Civic Si
28. is offline   Reply With QuoteReply With Quote
Old 08-07-2017, 01:32 PM #3
28.'s Avatar
28. 28. is offline
28. 28. is offline
28.'s Avatar
Make sure your battery cables are on tight and battery posts are clean from build up.. Also check your truck's ground cable..
2017 Civic Si
Old 08-07-2017, 01:38 PM #4
28.'s Avatar
28. 28. is offline
28. 28. is offline
28.'s Avatar
Maybe this will help..
http://www.toyotanation.com/forum/sh...d.php?t=394767
2017 Civic Si
Old 08-07-2017, 04:11 PM #5
vastano vastano is offline
vastano is on a distinguished road
I know you said your starters fine, but since its out, you may want to check/change the contacts. They can wear prematurely and cause the symptoms youre having.
vastano is offline   Reply With QuoteReply With Quote
Old 08-07-2017, 04:28 PM #6
TowMeOut's Avatar
TowMeOut TowMeOut is offline
TowMeOut is on a distinguished road
TowMeOut's Avatar
So you said no "click" no start, etc. right? So it's not even turning over. Sounds like an interlock kind of problem. The truck has all the nanny features so it will only start in park. However, if it's in park but not running there's an interlock that won't let you shift out of park.
Pop the little square hatch (fingernail sized) next to the shift lever. Depress the switch inside and shift it out of park. Run that back and forth a few times then back to park. Give that a shot. Maybe/hopefully that will work the switch loose.
This might help too:
2005 4Runner Won't Start Intermittently
Good Luck
06 Sport 4x4
185K and counting
Bilsteins, FJ/Tacoma springs
Nitto Terra Grapplers
TowMeOut is offline   Reply With QuoteReply With Quote
Old 08-08-2017, 09:01 PM #7
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
Try another key, they do have chips.
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 08-08-2017, 10:11 PM #8
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
Tighten the battery connections. I had these same symptoms before.
46runner is offline   Reply With QuoteReply With Quote
Old 08-09-2017, 02:15 AM #9
LordAbdullah LordAbdullah is offline
LordAbdullah is on a distinguished road
I had this issue once after I finished working on some electrical wiring, I had unplugged one of the harnesses and the car just wouldn't start, no crank nothing - i plugged it back in and there it went!
LordAbdullah is offline   Reply With QuoteReply With Quote
Old 08-09-2017, 10:20 AM #10
Real Name: Jeff
Real Name: Jeff
Thank you
Thank you for the advice, I've tightened the terminals, cleaned them, swapped batteries.
I never had an intermitted problem, it just happened out of the blue, with out any additional wiring work.
My thoughts were it could still be the security alarm giving me fits, tried resetting it with the key fob. No joy. Tried starting in neutral, no joy.
Used a testing probe that could energize the starter and it would start to turn but would not turn over.
Close to admitting defeat and getting it towed.
Old 08-09-2017, 11:55 AM #11
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
You pulled the starter which in itself is a PITA job by pulling the upper intake manifold. So, you have the skills and I bet we can help you with the troubleshooting issue.
Have you tried to wiggle the shifter from P to N while holding the key in IGN mode? I wonder if the Neutral Safety Switch (NSS) is making poor contact? Or maybe the NSS connector is loosy/goosy? This is common in the landcruisrers as well due to age and crud making their way into the contacts. I have a 80 series but thankfully hasn't happened to me yet!
I live in Tijeras so I can come down to help you after work one day. Shoot me a PM with your contact details and I'll see what I can do. Anything to save money is a priority in my book.
Ali
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 08-09-2017, 06:17 PM #12
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if you have a alarm installed, try to hit the unlock on the remote first. then try to crank the truck again, could be the started kill still activated. if you know where the relay for it is, just unhook the ground trigger to it. take pictures and show us whats underneath the dash and i might help you solve the problem. to me right now, it sounds like a active starter kill doing its job.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 08-13-2017, 05:02 PM #13
BADCUDA1 BADCUDA1 is offline
BADCUDA1 is on a distinguished road
Any update?
BADCUDA1 is offline   Reply With QuoteReply With Quote
Old 08-13-2017, 05:26 PM #14
GreenMachine GreenMachine is offline
GreenMachine is an unknown quantity at this point
There are also 2 relays in the engine compartment box you should check, the ACC Cut Relay and the Starter Relay.
GreenMachine is offline   Reply With QuoteReply With Quote
Old 08-13-2017, 05:38 PM #15
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Ali
Did he mention it was a V8? I assumed if he had the starter out it was probably a V6 since he didn't mention the annoying placement of it (on the V8).
@El_Jefe_83
Does your vehicle have an aftermarket alarm installed? Make sure it didn't have a "Port/Dealer" unit installed. IF It does have one of those, pop the steering column cover off, locate the start signal wire off the ignition that they cut and tapped for the alarm, bridge the splice with a paper clip, new piece of wiring, and/or just cut and restore the wire to factory. IF the vehicle starts or at least cranks after doing this, it's the alarm unit and/or relay that's gone out on you.
IF that's not the case we'll see what we can do to help out on our end.
Post Note-
If the vehicle won't even turn over, it's not a Toyota security issue. If the Immobilizer was acting up you'd still have the ability to crank the vehicle over but it would not fire the injectors or ignition system (because that's how it disables the vehicle until an appropriate key is detected). Also you'd see the "security" light flashing with a known good key in the ignition (this would indicate the vehicle does not detected a registered key).
BlackWorksInc is offline   Reply With QuoteReply With Quote
Crank no start 4runneracerunner Classic T4Rs 35 08-19-2017 04:46 PM
3RZ Crank, No Start Red October 3rd gen T4Rs 4 08-13-2016 03:51 PM
Starting issue... Crank and no start. the great him 3rd gen T4Rs 30 09-24-2014 12:47 AM
Remote start issue 2010 SR5-excessive crank time Fixmandan 5th gen T4Rs 2 04-08-2010 03:29 PM
Crank, NO start... Please help! VALERIEP81 3rd gen T4Rs 7 12-15-2009 08:05 PM
