Old 08-10-2017, 09:27 PM #1
doubleA doubleA is offline
doubleA is on a distinguished road
brakes/bleeding
hi all
i am planning on changing my rotors/pads soon.
I found through searching that bleeding the brakes requires a computer hookup? I ask because if I need new calipers will I be able to bleed the brakes?
doubleA is offline   Reply With QuoteReply With Quote
Old 08-10-2017, 10:37 PM #2
pearlj10 pearlj10 is offline
pearlj10 is on a distinguished road
The dealer may use Toyota's tech stream to bleed, but you can do it just fine w/o it. That being said, several members have had issues bleeding these brakes. Leave key in on position. Pump will bleed rears w/o pushing on brake pedal (!). Fronts get bled the old fashioned way. Do not press too hard on the brake pedal when bleeding, as you can damage the internal master cylinder components. Lots of advise on whether to start bleeding at farthest cylinder from master, or whether you should follow Toyota's sequence for bleeding. If you let the master run low or dry while bleeding, you will end up having to tow to dealer so the tech stream software can open and close the solenoid to get all the air out. Be particularly careful with the fluid levels when cracking the rear bleeders open with key on.
Best of luck!
pearlj10 is offline   Reply With QuoteReply With Quote
Old 08-11-2017, 04:24 PM #3
luke87gt's Avatar
luke87gt luke87gt is offline
luke87gt is on a distinguished road
luke87gt's Avatar
Best of luck!
Seriously? Top off master cylinder, put key in on position, and the rears will be bled automatically? Never heard of this before.
On position means start the car?
2006 4-Runner XSP V6
SCS Ray10 17x8.5 (Matte Black)
Falken ATW3 Wildpeak 265/70/17
Daystar 2.5/1.5
luke87gt is offline   Reply With QuoteReply With Quote
Old 08-11-2017, 06:30 PM #4
jfry008's Avatar
jfry008 jfry008 is offline
jfry008 is on a distinguished road
jfry008's Avatar
Originally Posted by doubleA View Post
hi all
Download the factory service manual
Bleeding brakes
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines//http://www.toyota-4runner.org/4th-ge...ld-thread.html
jfry008 is offline   Reply With QuoteReply With Quote
Old 08-11-2017, 06:46 PM #5
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
hi all
that would only be needed if you somehow get air into the MC/ABS unit. if no air, you don't need a scan tool.
also, to prevent issues, when compressing the pistons into the calipers, crack the bleeder open, and let then excess fluid out there. don't force it back up the line, into the MC/ABS.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-11-2017, 11:32 PM #6
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
I just did it on mine, old school 2 people brake bleeding. Pressed pistons back with small pry bars, screw drivers. Nothing special. No scan tool.
2005 V6 LTD 186k
benztech82 is offline   Reply With QuoteReply With Quote
Old 08-14-2017, 10:33 AM #7
thanks all!9
bleeding brakes Louie Maintenance/Detailing 33 02-27-2016 12:18 AM
Need some help - Bleeding brakes wkeryder4 4th Gen T4Rs 8 08-23-2014 12:05 PM
Bleeding my brakes oa8888 Maintenance/Detailing 5 12-21-2009 08:15 PM
Bleeding brakes sciff5 4th Gen T4Rs 1 03-14-2009 06:46 PM
Bleeding Brakes kimboy Maintenance/Detailing 3 07-06-2008 05:47 PM
