Originally Posted by Inv4drZm
How do you have most of the bumper cut out without planning for the mounting? I'm an engineer and that just hurts my brain.
The 4x4Labs rear bumper requires cutting the rear crossmember but it bolts to the factory tow hitch weld nuts underneath the frame rails. Also to the insides of each frame rail with plates w/ weld nuts you fish inside the frame through the ends (where you cut the frame crossmember off).
Probably all the aftermarket bumpers out there mount to those weld nuts underneath the frame rails so that would be a good place to start.
Thanks man, that's pretty much where I was going or assumed.
All of the "shell" i've already cut out. I thought it would be easier to Engineer the mounts after I've tacked the center section together. Didn't really wanna take the time to model up the whole Assy in Solidworks.
I was just curious how all the main bumper fabricators were doin it.
This site is a lotta help and looking forward to hopefully contributing.
At least I was lazy enough to Order a front bumper from addicted Offroad 😄
