Old 08-28-2017, 06:20 PM #1
FortCollinsT4R FortCollinsT4R is offline
FortCollinsT4R is on a distinguished road
Front end noise
Hey everyone!
06 4th gen V8 4x4 80K miles.
I've got a noise in my front end somewhere. It sounds like a wheel bearing noise but only makes the noise while I have my foot on the accelerator, when I let off it seems to go away. I have recently replaced both front wheels bearings to try to solve the problem, obviously didn't fix the issue. I am now considering dropping the front diff to replace the outter bearings and the pinon bearing etc. while in there to chase this noise. Also, last Friday, I dropped the front driveshaft to feel the u-joints, no stiff spots at all. I am at a loss now, has anyone experienced experienced this issue or have any advise?
Thanks in advance.
FortCollinsT4R is offline   Reply With QuoteReply With Quote
Old 08-28-2017, 06:40 PM #2
gaber6 gaber6 is online now
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
When I purchased my used 2005 with 140k, I for sure thought it had a bad front bearing, but the dealer replaced a rear bearing and it solved the issue. I could hear and feel it in the steering and pedals, but low and behold, all quiet and smooth now.
gaber6 is online now   Reply With QuoteReply With Quote
Old 08-28-2017, 07:46 PM #3
That's interesting man. I'll have to see what I can do there as far as checking for noises while it's up in the air. Thanks for the reply!
Old 08-29-2017, 12:22 AM #4
MR24U MR24U is offline
MR24U is on a distinguished road
Do you notice a difference between 2 and 4wd? I had a similar problem on my 3rd gen, turned out to be a bad universal in the rear driveshaft. Found destroyed needle bearings when I took it apart.
MR24U is offline   Reply With QuoteReply With Quote
Old 08-29-2017, 12:50 AM #5
Ryanmb21 Ryanmb21 is offline
Ryanmb21 is an unknown quantity at this point
I had a little clunk noise that turned out to be the LCA bolt, was able to crank it a bit and get it tighter. Maybe give a shot.
Ryanmb21 is offline   Reply With QuoteReply With Quote
Old 08-29-2017, 09:17 AM #6
Well unfortunately in this particular situation my V8 with full time 4x4 doesn't help. I tired to just remove the front drive shaft but the car then will not move due to all power going to the front, thinking the wheels are stuck or something. Also, my noise isn't a clunky noise, it's a humming/rotational noise.
Old 11-23-2020, 01:12 AM #7
nlau87 nlau87 is offline
nlau87 is on a distinguished road
Front end clunk
I get a front end noise going over dips or bumps. I’ve removed the skip plates and the sway bar including the links but no luck.. the sound didn’t go away and it drives me crazy. I have bilstein 5100 installed about 4 years ago and also had my LCA’s replaced about 2 years ago. Any ideas what might be the issue?
Video with sound:
Toyota 4Runner (2007 4th gen) front end noise over dips or bumps - YouTube
nlau87 is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 09:40 AM #8
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Originally Posted by FortCollinsT4R View Post
Hey everyone!
Thanks in advance.
Pinion bearing seems pretty logical given the circumstances. I would check the fill level by pulling the fill plug and topping it off. See how much it takes. Then take it for a spin. If you're lucky and this is relatively new you may get away with just having the correct amount of fluid (if it was indeed low).
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 05-16-2024, 11:59 AM #9
grocery_getter grocery_getter is offline
grocery_getter is on a distinguished road
@FortCollinsT4R
I have the same situation, what was your end result?
I jacked up all four tires had it in Drive and put a stethoscope to the front diff and that's definitely where the noise is coming from. I haven't been able to find much of any information on front and if pinion bearing replacement so any advice or foresight will help. Thanks in advance
grocery_getter is offline   Reply With QuoteReply With Quote
Old 05-16-2024, 12:01 PM #10
@FortCollinsT4R
Old 05-16-2024, 12:47 PM #11
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Originally Posted by grocery_getter View Post
@FortCollinsT4R
While you have the front differential open, check the gear teeth for any wear, chips, or strange patterns.
Make sure the gears are fitting together correctly because if they're not, it can cause noise and make the bearings wear out faster.
Also, have a look at other parts like the carrier bearings and seals for any signs of damage, as that could also be causing the noise.
Plus, I'd check the fluid level and condition in the differential. If it's dirty or too low, it can make noise.
weberlukas74 is offline   Reply With QuoteReply With Quote
Front end noise Gus04Runner 4th Gen T4Rs 4 04-18-2017 06:19 PM
Front End Noise ToyNutt 3rd gen T4Rs 0 08-12-2014 06:24 PM
Front End Noise bigsp 5th gen T4Rs 1 04-21-2014 04:01 PM
Front End Noise BostonBeachbum Problems & Warranty Issues 1 04-20-2009 02:00 PM
Front End Noise kwc280 3rd gen T4Rs 2 09-03-2008 06:15 PM
