08-31-2017, 06:37 PM
Issue Rolling Rear Window Up With Key
The rear window works fine from the switch within the vehicle on the dash. The window will roll down all the way with the key FOB button, but when I put the key in the lock on the rear door I cannot get the window to roll up. At all.
I don't hear anything clicking or like something is trying to work. Just nothing. Also, how far would the key need to turn? I'm hoping maybe it's just stuck from not being used and not a motor issue... That doesn't make sense though because the window works fine otherwise.
Any suggestions?
Edit: Sorry! To be clear this is on a 2004 SR5 V6.
2004 SR5 V6
08-31-2017, 10:56 PM
Real Name: Chris
Real Name: Chris
It’s working as it was designed to work. Bummer, eh?
Chris - '07 SR5
‘05 Limited - sold
08-31-2017, 11:15 PM
What? 3rd gen can roll up with key, but 4th gen doesn't?
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
08-31-2017, 11:23 PM
Real Name: Skip
Real Name: Skip
My 2004 goes down and back up with the key, should only have to turn the key less than 1/4 turn for it to work, if it doesn't you could have a problem with the switch since it still works with the key fob/remote and dash switch.
2004 Limited V8
09-01-2017, 01:29 AM
Yeah I guess I should have mentioned for others who viewed the thread.
I have a 2004 V6 SR5. Hmm it does seem like there some issue going on back there with the switch potentially. Everything else on it functions normally.
2004 SR5 V6
09-01-2017, 02:33 AM
might need to cycle the inside switch auto feature, try that and also check the window lock button.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
09-01-2017, 02:50 AM
Try hitting the cylinder with some graphite lube and working it a bit. Sometimes those rear key cylinders can get sticky in one direction. It's just a keyed switch so you probably won't hear anything besides the key turning.
09-01-2017, 10:20 AM
When you mean "try hitting the cylinder" do you mean around the lock or somewhere else beneath the covering of the door?
I think I've already done that because initially when I got the car the key FOB button would not lower the window at all. It would just beep. I performed the said reset and now it lowers with no issues.
2004 SR5 V6
09-01-2017, 11:09 AM
Had same problem with my '03. In my case, the key cylinder wouldn't rotate all the way to engage switch. After trying several attempts at spraying lube and break free in cylinder, I finally had to replace cylinder and key with a new set. Now it works fine, but I now have an additional key on my key ring.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
09-02-2017, 02:26 AM
Originally Posted by Ultryx
When you mean "try hitting the cylinder" do you mean around the lock or somewhere else beneath the covering of the door? I think I've already done that because initially when I got the car the key FOB button would not lower the window at all. It would just beep. I performed the said reset and now it lowers with no issues.
I usually get the graphite stuff in a small can and it comes with a small plastic tube, stick that into the actual lock cylinder where the key goes and spray it.
I don't know if rust is an issue in your area, you may want to hit it with a small puff of PB Blaster and let it sit before working it with the key, then using the graphite to lube it. The key here is small amounts of spray, you don't want to just blast this thing like a hurricane, you're looking to break it loose and lubricate it lightly. Not baste it like a thanksgiving turkey (mostly because all that stuff will run inside of the door).
09-02-2017, 10:07 AM
Hmmmm.....I just tried on my '06 Sport and the key only turns about 45-degrees clockwise. I don't hear a click or anything. I tried a couple of combinations of locking the vehicle with the fob then trying to unlock with the key but it doesn't seem to do anything. Is this correct??
My key doesn't turn at all counterclockwise. Is it supposed to??
If I drop the rear hatch with the key fob, insert the key and turn it then the hatch goes back up. Is this the only function of the rear hatch key (to raise the rear window)?
I'm assuming this is in the owners manual. I'd better start digging through the glove box.
06 Sport 4x4
185K and counting
Bilsteins, FJ/Tacoma springs
Nitto Terra Grapplers
09-02-2017, 11:58 AM
About every 6 months I need to reset the computer that controls the windows, to fix my window issues
09-02-2017, 04:43 PM
On my '03 Limited, the rear key switch works as follows:
With vehicle locked, turning rear hatch key to left (counter-clockwise), you can hear vehicle unlock, and two seconds later (if you keep key in left position) the rear hatch window goes down. If you then turn key to right of the center position (clockwise), you hear the vehicle lock, and in two seconds the rear hatch window will go up. The lock/unlock function at the rear key switch also locks/unlocks all the side doors.
05-27-2019, 09:28 PM
For the record, 4th gen 4Runner back windows can be raised and lowered with the key in the liftgate key cylinder. Counter clockwise to lower, clockwise to raise.
Mine got sticky in the counter clockwise (lowering) direction. I cleaned and lubed the cylinder by wetting the key and inserting it multiple times, and wicking light oil into the cylinder. This made things much smoother. However, the key needs to be given downward/rightward pressure in order to turn counter clockwise. The electrical aspect works flawlessly, just the key cylinder has some wear and needs to be fussed with to function properly.
2005 4Runner SR5 V6 4WD
